Schrodinger Equation for Potential Well
The discussion focuses on solving the time-independent Schrödinger equation (TISE) for a particle of mass m with total energy E < 0 confined in a potential well. The wavefunction given is Nx exp(-αx), and participants confirm that substituting this wavefunction into the TISE demonstrates it is indeed a solution for x > 0. The process involves calculating the second derivative of the wavefunction and rearranging to find the energy eigenvalue E, which is derived as a constant multiple of the wavefunction.
  • Understanding of the time-independent Schrödinger equation (TISE)
  • Familiarity with wavefunctions and their properties
  • Knowledge of derivatives and their application in quantum mechanics
  • Concept of energy eigenvalues in quantum systems
  • Study the derivation of energy eigenvalues in quantum mechanics
  • Learn about boundary conditions in quantum potential wells
  • Explore the implications of wavefunction normalization
  • Investigate the role of potential wells in quantum mechanics
Students of quantum mechanics, physicists working with wavefunctions, and anyone studying the Schrödinger equation and its applications in potential wells.
freddy_12345
A particle of mass m and total energy E < 0 is confined to a potential given by:
where [tex]\alpha[/tex] is some positive constant.
Show that the wavefunction
is a solution of the time independent Schrödinger equation when x > 0. Find the associated energy Eigenvalue E.
The TISE:
The second part of the question is straightforward: you take the equation for [tex]\psi[/tex](x) and its second derivative and plug them into the TISE, cancel and rearrange for E. I got:
Which I'm over 50% sure is correct.
But for the first part, what does it mean to show that Nx exp (-[tex]\alpha[/tex]x) is a solution?
You've basically already done the first part. All you need to do is plug it into the left-hand side of the TISE, calculate the derivatives and show that for x>0, you get a constant times the wavefunction for all values of x>0. Doing so, proves that it is a solution to the TISE (If it weren't, then you would not end up with a constant multiple of the wavefunction when you calculate the LHS). The second part simply asks you for the value of that constant (E).
