Units into Log and Exponential Functions
The discussion centers on the treatment of units when they are input into exponential and logarithmic functions, particularly in the context of neutron attenuation and other physical equations. Participants explore whether these functions can accept dimensional arguments or if they must be dimensionless, raising questions about the implications for physical quantities and mathematical consistency.
  • Some participants propose that exponential functions can only take dimensionless arguments, suggesting that the argument must be adjusted to ensure dimensional consistency.
  • Others argue that they have encountered equations with dimensional arguments, questioning the claim that exponentials must be dimensionless.
  • A participant explains that in physical quantities, magnitude and dimension are inseparable, and that exponentiation of a dimension raises questions about the resulting dimensions of the output.
  • Another participant mentions the Geiger-Nuttall law as an example that seems to contradict the idea of dimensionless arguments, but also notes that it can be reformulated to fit the dimensionless requirement.
  • There is a discussion about the pH scale in physical chemistry, where the logarithm is described as dimensionless when considering standard states.
  • Some participants express confusion and seek clarification on the dimensionality of various functions and their arguments.
Participants do not reach a consensus on whether exponential and logarithmic functions can accept dimensional arguments. Multiple competing views remain, with some asserting the necessity of dimensionless inputs while others provide counterexamples and seek further clarification.
Participants highlight limitations in understanding related to specific equations and contexts where dimensionality may not be obvious. The discussion also touches on the need for careful definitions in texts regarding the treatment of units in logarithmic and exponential functions.
terryphi
Hello,
Something I've wondered about for some time is what happens to units once we pump them into a exponential or log function.
For example in neutron attenuation
I(x) = I_0 * exp(-Sigma * x)
I feel like this something I should know, but I just don't get it.
I suspect what's happening is that the units stay the same since basically all the function is doing is changing the magnitude of the scalar quantity associated with the unit, and not necessarily what the unit measures.
If that's so is there a word I can use to describe a function that does change a inputs unit (such as the aformentioned) and one that does not?
terryphi said:
Hello,
This is a bit puzzling to understand.
If I've read it correctly, then you might have a problem understanding that the argument for the exponential above must be dimensionless. This means that whatever units x has, sigma must have the inverse of that unit.
The same with logarithm.
Zz.
Sorry,
an exponential function can only take a dimensionless argument?
Yes.
Sorry, I've never heard this, and I've used several equations which I'm relatively sure have had dimensional arguments.
Can you give some sort of explanation?
In a physical quantity, magnitude and dimension are inseparable -- whatever function you have of its magnitude also applies to its dimension. Trivial example: Square area A = x2. If you know that [x] = m, you also know that [A] = m2, i.e. that area is measured in m2.
However, ex is problematic -- what, exactly, is the exponentiation of a dimension supposed to mean? To better see the problem, expand into a powerseries: f(x) = ex = 1 + x + x2/2! + x3/3! + ... If x now has dimension [dim], the first summand is dimensionless, the second of dimension [dim], the third of dimension [dim]2, and so on. So, what dimension is whatever quantity is denoted by f(x) supposed to have? There's no unique assignment possible. Only if x is dimensionless does one get a unique dimension for f(x) -- which is none, as well.
Note that this extends to other non-polynomial functions too, like the sine/cosine functions, and anything that can be made out of them (cosh,sinh,spherical harmonics, bessel functions, etc.).
What if you show us what equations you used, and I'm sure we can point out where you made your mistake of thinking they had a dimension.
Zz.
terryphi said:
Sorry,
I imagine you would find it hard to evaluate e(5 bannanas).
That's why an exponential must be dimensionless.
Zz.
Heh, I just realized you're right. Every function I can think of is dimensionless!
Thanks PF :D
The Geiger-Nuttall is an empirical numerical formula, obtained basically from curve-fitting to data. The values of the coefficients depend on the specific units used for time and energy.
Note that you can re-cast it into a form in which the argument of the logarithm is dimensionless, by writing copies of the equation for isotopes 1 and 2 and subtracting one from the other:
[tex]\ln {\frac{\lambda_2}{\lambda_1}} = -a_1 \left( \frac{Z_2}{\sqrt{E_2}}<br /> - \frac{Z_1}{\sqrt{E_1}} \right)[/tex]
In this version the coefficient [itex]a_2[/itex] drops out. I don't have any appropriate textbooks to check here at home, but I suspect the derivation of the Geiger-Nuttall law by Gamow et al. produces something like what I wrote.
I know of some examples where the question of dimensions is also not obvious namely physical chemistry where e.g. you can find definitions in textbooks like "the pH is the negative decadic logarithm of the concentration of hydronium ions".
However, in more careful texts you will see that what enters is always the quotient of the concentration (or activity to be more precise) and the concentration in some standard state, so that the argument of the logarithm is in fact dimensionless.
Surely a quantity may have dimensions but a number can have none. Is there anything more to be said?
So is that a good measure of a book? If they have logs with units?
The book may have a lot of good and correct iknfo in it. It just didn't make it clear that the exponential was dimensionless.
11K
