Compound Interest Formula and Natural Logarithms
The discussion focuses on solving the compound interest formula for time (t) using natural logarithms. The formula presented is A = P(1 + r/n)^(nt). The user attempts to isolate t by taking the natural logarithm of both sides but makes an algebraic error in their calculations. A response points out the mistake, indicating the need to divide by n*ln(1 + r/n) to correctly solve for t. The user acknowledges the oversight and expresses gratitude for the clarification.
adillhoff
Solve the compound interest formula for t by using natural logarithms.
A=P(1+\frac{r}{n})^{nt}
I start by dividing both sides by P.
I then take the natural log of both sides and end up with
ln(\frac{A}{P})=nt * ln(1+\frac{r}{n})
I isolate t to one side by first dividing by ln(\frac{A}{P}) then by t.
I end up with t=\frac{n*ln(1+\frac{r}{n})}{ln(\frac{A}{P})}
I don't believe this is the correct answer. I can't seem to see which step I overlooked at the moment. Any help would be greatly appreciated.
You made a simple algebraic mistake in the step where you solve for t. You need to divide by n*ln(1+r/n).
Of course. I knew I missed something simple. Thanks for the reply.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
