Confused by radial vs. centripetal acceleration
The discussion centers around the concepts of centripetal and radial acceleration, particularly in the context of circular motion. Participants explore the definitions, mathematical representations, and implications of these types of acceleration, as well as the influence of sign conventions and changing radii.
  • One participant expresses confusion about the difference between centripetal and radial acceleration, noting that both terms seem to be used interchangeably in their textbook.
  • Another participant agrees that centripetal and radial acceleration refer to the same concept, emphasizing that the sign depends on the chosen coordinate system.
  • A participant explains that the negative sign in the expression for radial acceleration arises from the definition of direction, which can vary based on the axis chosen.
  • It is noted that radial acceleration equals centripetal acceleration when the radius is constant, but additional terms must be considered if the radius changes over time.
  • Further details are provided regarding the inclusion of tangential acceleration and other effects when analyzing motion with a changing radius.
Participants generally agree on the relationship between centripetal and radial acceleration, but there are nuances regarding the sign conventions and the implications of changing radii that remain contested.
Some assumptions about the definitions of acceleration types and the choice of coordinate systems are not explicitly stated, which may lead to different interpretations of the signs in the equations presented.
eventob
Hi
I've been working through some examples from the course material we use in physics class, but one thing keeps confusing me: What is the difference between centripetal and radial acceleration?
For instance, when we have a particle traveling in a circular path, the acceleration towards the center of the circle may be written as Ar (a sub r)=-Ac= - v^2/r, while other times it is written simply as Ac=v^2/r. The textbook (JS Physics for Scientists and Engineers) seems to use both.
Where is the negative sign coming from? I made a quick sketch. Am I right if i think that the radial acceleration is negative in the first circle (to the left) and it is positive in the circle to the right? Is it just due to how I pick the axis and how I define positive direction?
Thanks in advance.
Same thing.
v^2/r is the magnitude of the radial acceleration; the direction is toward the center. Whether that's positive or negative just depends on how you define your sign convention.
Yes.
Thank you very much. :)
Radial acceleration is equal to centripetal acceleration when the radius remains constant (with a +/- sign depending on definition). If radius changes as a function of time, you have to add the explicit second derivative of radius with respect to time.
[tex]a_r = a_c + \ddot{r} = -\omega^2 r + \frac{d^2r}{dt^2}[/tex]
Similarly, tangential acceleration will pick up a term that depends on the second derivative of angle with respect to time and a Coriolis Effect term.
  • · Replies 16 ·
  • · Replies 37 ·
  • · Replies 24 ·
