Showing that x and 1+x² are solutions to this DE
  • Thread starter Thread starter MuhTheKuh
MuhTheKuh
Hiya guys, I'm stuck on this new topic...
How do I show that x and 1+x² are both solutions to
(1-x²)*(d²y/dx²)+2x*(dy/dx)-2y=0
Thanks for your time
A solution to a differential equation is one which, if you substitute it for y in your equation, you get zero on the left hand side like you're supposed to.
Can you substitute y=x and y=1+x2 into (1-x^2)\frac{d^2 y}{dx^2} + 2x \frac{dy}{dx} - 2y and see what you get?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
