New Reply
Thermal expansion bt. steel rule and vycor glass brick
Share Thread Thread Tools
Dec10-10, 05:12 PM   #1
A steel rule is calibrated for meauring lengths at 20.00 C. The rule is used to mesure the lenght of a Vycor glass brick; when both are at 20.00 C the length is 25.00cm. What is the length of both the rule and the brick when at 80.00 C
2. Relevant equations
coef of glass a=.75 *10^-6K
coef of steel a=12*10^-6 K
3. The attempt at a solution.75*10^-6K *60.0 (the diff of Temp)*25.0 (L inital)
after this I am confused
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Dec10-10, 05:43 PM   #2
Mentor
Quote by mg1977 View Post
I don't think you've listed the coefficient equations quite right. The "K" that you've put at the end of each -- is that meant to signify that the units are 1/Kelvin? Because linear coefficients of expansion are in units of meters per meter Kelvin (m/m*K), or meters per meter Celcius (m/m*C).
http://en.wikipedia.org/wiki/Thermal_expansion
And to your question, how do you apply a linear coefficient of expansion to calculate the change in length?
Dec10-10, 06:08 PM   #3
I was using the books list. So should I still use the Coeffient for glass even though the problem says to assume that the glass doesn't expand in this problem.What is the proper way to set up my formula and coeff ? Can you show me another way?
Dec10-10, 06:20 PM   #4
Mentor
It doesn't say anywhere in your original post that the glass brick does not expand. Have you posted the full text of the question?
And as for how to use the coefficients to calculate the change in length, surely your book has examples on how to do it...?
Dec10-10, 06:22 PM   #5
a is linear coeffient and B is volume expansion coeffiecient.
Dec10-10, 06:25 PM   #6
No, there aren't many examples in the book on this . The question i asked is asked completely by my second response. Sorry about that.
Dec10-10, 06:35 PM   #7
Mentor
Look at the link in my post #2. It has the equations you need for calculations of linear coefficients of expansion.
New Reply
Thread Tools
Similar Threads for: Thermal expansion bt. steel rule and vycor glass brick
Thread Forum Replies
Thermal expansion of a glass bottle Introductory Physics Homework 1
Thermal Expansion of Aluminium Sleeve over Steel shaft Introductory Physics Homework 1
Thermal conductivity of glass Introductory Physics Homework 0
Steel Glass? Materials & Chemical Engineering 2
