Air Cannon Projectile Velocity Calculations help please
Calculating the initial velocity of a projectile in air is complex due to the effects of drag, which complicates the separation of horizontal and vertical motions. The user successfully calculated the initial velocity in a vacuum at approximately 111 feet-per-second but is struggling to determine the velocity in air, given a total distance of 380 feet and a flight time of 2.5 seconds. It is suggested that firing the projectile straight up could provide data to calculate initial velocity, alongside determining its terminal velocity. The significant discrepancy between the calculated initial velocity and the observed time of flight indicates that drag plays a crucial role, and the expected flight time should be closer to 5 seconds. Additional factors like wind conditions may also need to be considered in the calculations.
grapefruit355
Hi everyone, I am new here at Physics Forums and this is my first post.
Earlier this evening, my dad and I were trying to figure out the initial velocity of our projectiles. We were successful in calculating the initial velocity in a vacuum, but we are perplexed as to how to calculate the velocity in air. Here is the data we gathered:
Total distance traveled by projectile: 380ft
Time to impact from launch: 2.5 seconds
Angle of launch: 45 degrees
Temperature at time of launch: 45 degrees Fahrenheit
Dimensions of projectile: 2 inch diameter x 3 inch long cylinder
Force of gravity: 32.15223 ft/s/s
Initial Velocity in a vacuum: ~111 feet-per-second
Again, we would like to know the initial velocity of the object traveling through the air. If you can provide an answer, that's great, but we would also like an explanation to feed our starving minds :)
Cheers, and thanks in advance!
You need to also provide mass of the projectile.
There is no analytical solution to a projectile with drag, because horizontal and vertical motions don't separate. Pure vertical motion has a solution, however. If there is a way to safely fire the thing straight up and time the flight, that data can yield initial velocity. Especially if you run a separate experiment to find terminal velocity of your projectile.
Initial velocity neglecting drag results in too large a disparity with your time of flight. It should be closer to 5s. Even if your projectile tumbled, I don't see how drag alone would account for that big a difference. Wind wouldn't account for that either, though, that's another thing you might want to mention.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
