How Do You Differentiate 1/sqrt(x) Using Limits?
  • Thread starter Thread starter Pithikos
    Derivative
The discussion revolves around finding the derivative of the function \( \frac{1}{\sqrt{x}} \) using the limit definition of the derivative. Participants are exploring the application of the limit process in calculus.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the initial setup of the limit definition and the manipulation of expressions involving fractions. There is an attempt to combine fractions and simplify the expression, with some participants expressing confusion at certain steps.
Some participants have provided guidance on how to proceed with the problem, suggesting ways to combine fractions and check for cancellations. Others have noted alternative forms of the function that could simplify the differentiation process.
There is a repeated emphasis on using the limit definition, and some participants have reiterated the importance of careful manipulation of the algebra involved. The discussion reflects a collaborative effort to clarify the steps without reaching a final solution.
Pithikos
Find the derivative of [tex]\frac{1}{\sqrt{x}}[/tex] using the lim definition.
f(x)'=[tex]\frac{f(x+h)-f(x)}{h}[/tex]
Keep in mind that everything bellow is for the lim as h approaches 0.
[tex]\Downarrow[/tex]
[tex] \frac{<br /> \frac{1}{\sqrt{x+h}}-\frac{1}{\sqrt{x}}<br /> }<br /> {h}[/tex]
(I multiply both nominator and denominator with conjugate)
[tex] \frac<br /> {<br /> \frac{1}{x+h}-\frac{1}{x}<br /> }<br /> {<br /> \frac{h}{\sqrt{x+h}}+\frac{h}{\sqrt{x}}<br /> }[/tex]
After this I am totally lost..
Combine numerator into a single fraction. See if you get an h you can cancel with the h in the denominator.
You could also use the definition...
[tex]f'(x)= \lim_{ x \to a} \frac{f(x)- f(a)}{x-a}[/tex].
Thaaaank you! Problem solved! :)
Did the same to denominator and then combined the two franctions into one.
Glad you got it solved. As a check, remember that you can write [itex]\frac{1}{\sqrt{x}}[/itex] as [itex]x^{-1/2}[/itex] and use the power rule.
[tex] \frac<br /> {<br /> \frac{1}{x+h}-\frac{1}{x}<br /> }<br /> {<br /> \frac{h}{\sqrt{x+h}}+\frac{h}{\sqrt{x}}<br /> } [/tex]
This is perfectly fine - up to this point.
Continuing on:
[tex]\displaystyle =\frac<br /> { \displaystyle \frac{x-(x+h)}{(x+h)x}<br /> }<br /> { \displaystyle \frac{h}{\ \sqrt{x+h}}+\frac{h}{\sqrt{x}\ \ }<br /> }[/tex]
[tex]\displaystyle =\frac<br /> { \displaystyle \frac{-h}{(x+h)(x)}\ \cdot\ \displaystyle \frac{1}{h}<br /> }<br /> { \displaystyle \left(\frac{h}{\sqrt{x+h}}+\frac{h}{\sqrt{x}}\right) \ \cdot\ \displaystyle \frac{1}{h}}<br /> } [/tex]
[tex]\displaystyle =\frac<br /> { \displaystyle \frac{-1}{(x+h)(x)}<br /> }<br /> { \displaystyle \frac{1}{\sqrt{x+h}}+\frac{1}{\sqrt{x}}<br /> } [/tex]
Then,
[tex]\displaystyle f'(x)= \lim_{h\to 0} \ \ <br /> \frac<br /> { \displaystyle \frac{-1}{(x+h)(x)}<br /> }<br /> { \displaystyle \frac{1}{\sqrt{x+h}}+\frac{1}{\sqrt{x}}<br /> }[/tex]
  • · Replies 20 ·
