New Reply
Doorframe problem
Share Thread
Jan9-11, 01:58 PM   #1
Doorframe problem
A doorframe is twice as tall as it is wide. There is a positive charge on the top left corner and an equal but negative charge in the top right corner. What is the direction of the electric force due to these charges on a negatively charged dust mite in the bottom left corner of the doorframe?
So I know the how to divide into components and analyze in the x an y directions to figure out the net force in x an y direction. But the problem is the values I plugged in were not correct because it was wrong. my answer was 32 or so degree.
2. Relevant equations
3. The attempt at a solution
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan9-11, 04:05 PM   #2
Any brave souls?
Jan9-11, 04:45 PM   #3
Recognitions:
Homework Helper Homework Help
Maybe show a little more of your attempt?
Jan9-11, 09:35 PM   #4
Doorframe problem
So I assumed that the positive charge at the top left corner is 1.602e-19C, an elementary charge. Likewise, the negative charge at the top right corner is assumed to be -1.602e-19C. The dust mite, although unspecified of its value, is negatively charged, so I assumed its charge to be -1.602e-19C. So the attractive electrostatic force between the mite and the positively charged particle is (0, 5.768e-29)=(Fx,Fy) assuming that the length along the side is 2m and the width is 1m. For the repulsive force between the mite and the negative charge, the angle made by the diagonal line, connecting the mite and the charge, and the length of the doorframe is arcsin(1/sqrt(5)) or 26.565degrees. The net electrostatic force between the negatively charged particle and the mite is 5.768e-29 N. So, using trigonometry, I get (Fx,Fy)=(-2.5795e-29,-5.159e-29). Then summing the forces, (Fx,Fy)=(-2.5795e-29, 6.0895e-30). Theta is then, atan(6.0895e-30/-2.5795e-29)+360= 346.717degrees. Any flaw in this?
Jan9-11, 10:07 PM   #5
Recognitions:
Quote by Abelard View Post
I think you should recheck the force due to the negative charge at the top right corner. You may have used the length of the door frame instead of the diagonal. Also, estimate the quadrant that the resultant should fall in by looking at your diagram; make sure that your calculated angle for the resultant agrees.
Jan10-11, 04:29 PM   #6
I really don't have an intuitive sense as to where the resultant electrostatic force will point to. So all I can rely on is calculation. So the right angle is 320.3868? The angle is actually atan(1/sqrt(5)). So using the angle, 24.095degrees, the ordered set of x and y component of electrostatic force vector is (-1.88e-29,-4.212e-29). So adding up all the x and y forces, the resultant force will have (-1.88e-29,1.556e-29). So taking arctangent;atan(1.556e-29/-1.88e-29)+360= 320.38degrees since it's in the fourth quadrant.
Jan10-11, 04:54 PM   #7
Recognitions:
The distance from the top right corner to the bottom left is greater than the distance from the top left corner to the bottom left (the diagonal is longer than the side). Since all charges have the same magnitude you expect the magnitude of the force with the shorter separation to be larger. Or, if you prefer, the one with the larger distance between them will be smaller.
The force between charges always lies along the line joining the charges.
So, if you were to sketch the forces on the charge at the lower left you'd have one pointing along the direction of the diagonal to the lower left (repulsive), and one, slightly larger, pointing straight up towards the upper left corner. If you "add" these vectors graphically on your sketch, where does the resultant end up?
New Reply
Tags
coulomb's law, electrostatic forces
Similar discussions for: Doorframe problem
Thread Forum Replies
Geometry Problem in Context of Image-Charge Problem (Griffiths,p. 125, [3.15],[3.16]) Advanced Physics Homework 1
Inequality Problem from Spivak's Calculus: Chapter 1, Problem 4, Subproblem XI Precalculus Mathematics Homework 4
General solution of initial value problem --dont understand problem is asking me?? Calculus & Beyond Homework 1
One Kinematic Problem, One Pendulum Problem, One Wave Problem Introductory Physics Homework 7
classic E&M problem: point charge and a charged sphere, how to analyze this problem Advanced Physics Homework 1
