How can I securely fix a bearing inside a pipe without permanent installation?
  • Thread starter Thread starter hamdan_neo
    Bearing Pipe
To securely fix a bearing inside a pipe without permanent installation, one effective method involves drilling a hole through the pipe wall to access the outer race of a sealed roller bearing. A small socket head set screw can then be used to apply pressure on the outer race, securing it in place. For added stability, a jam-nut can be employed on the set screw to prevent movement. In cases of significant vibration, dimpling the outer race at the contact point can enhance security. This approach is recognized as a practical solution in machining and welding applications.
hamdan_neo
hello,
i want to fix a bearing inside a pipe but not "permanently" so i can remove it and change it whenever i need.
please if anyone has a method for fixing it, share it with me ?
If the wall is thick enough you could drill at least one hole through the wall of the pipe to intersect the location of the outer race, assuming this is a sealed roller bearing. You could then tap the hole with an appropriate thread for a small socket head set screw. Position the bearing where it will normally reside within the pipe and tighten the set screw to apply pressure to the outer race and secure it in place. I you were to use a longer than required set screw you could screw a nut down on the protruding segment of thread and tighten it after the bearing was secured to act as a Jam-nut which would aid in restricting the movement of the set screw.
I work in a Machining/Welding business and have used this as a ''Quick n' Dirty'' method for fastening an object temporarily inside a housing or enclosure.
Excellent suggestion, Molitor. If there is any significant vibration or stress upon the bearing, though, I would further recommend dimpling the outer race where the set screw contacts it, to secure it a bit better (like how a hand-held die is fixed in its handle).
If you want needless elegance, or to show off, you could thread the outside of the race and the inside of the pipe and screw them together. :biggrin:
Thanks a lot molitor, it is an excellent idea, i will work on it now ... really thanks again :D
I'm really glad I could help. I know thousands of tricks when it comes to applications. Its what I do for a living.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
