Del operator with coordinate transformations
The discussion revolves around expressing the del operator after a change of variables, particularly focusing on cylindrical coordinates in the context of fluid problems. Participants explore how to derive the del operator for arbitrary coordinate transformations and the implications of these transformations on the operator's components.
  • Some participants inquire about the expression of the del operator in cylindrical coordinates and the derivation process for other coordinate systems.
  • One participant outlines the geometric interpretation of cylindrical coordinates, describing the associated surfaces and normal vectors relevant to the del operator.
  • Another participant provides a detailed mathematical derivation of the del operator in cylindrical coordinates, emphasizing the use of the chain rule for transforming partial derivatives.
  • There is a discussion on switching between Cartesian and cylindrical bases, with participants providing relationships between the unit vectors in both systems.
  • Some participants express confusion regarding the generalization of switching bases for arbitrary coordinate transformations, suggesting that it may not always be straightforward.
Participants generally agree on the need for a mathematical framework to express the del operator in different coordinate systems, but there is no consensus on the best techniques for switching bases in more complex transformations. The discussion remains unresolved regarding the generalization of these methods.
Limitations include the dependence on specific coordinate systems and the potential complexity of transformations that may not have clear geometric interpretations.
Curl
How can you express the del operator after a change of variables? For example, if I want to use cylindrical coordinates for a fluids problem, what is the del operator in terms of the new coordinates?
And how do you derive it for any other arbitrary coordinate transforms?
1. A (3-D) set of coordinates can be said to specify three types of basic surfaces, each associated with holding one of the variables constant.
For example, for cylindrical coordinates, z=constant are planes parallell to the xy-plane, theta=constant are half-planes (ending in the line x=y=0) , whereas r=constant specifies a cylindrical shell.
2. To each of these surfaces, there will be, at every point, an associated normal vector, and the proper length element associated with a(n infinitesemal) change in a particular variable.
For the cylindrical coordinates, those length elements are:
[tex]dz, rd\theta, dr[/tex]
dz is the length element by changing from one z=constant plane to the "next", rdtheta the arc length you traverse between two half-planes each specified by a constant theta, and dr moving from one cylindrical shell to the next.
3. For an arbitrary coordinate system, our del-operator will look like:
[tex]\nabla=\vec{i}_{1}\frac{\partial}{\partial{l}_{1}}+\vec{i}_{2}\frac{\partial}{\partial{l}_{2}}+ \vec{i}_{3}\frac{\partial}{\partial{l}_{3}}[/tex]
where the vectors are the normal vectors, whereas [itex]\partial{l}_{1}[/itex] denotes the associated length element.
Thus, for cylindrical coordinates, we have:
[tex]\nabla=\vec{i}_{r}\frac{\partial}{\partial{r}}+\vec{i}_{\theta}\frac{\partial}{r\partial\theta}+ \vec{i}_{z}\frac{\partial}{\partial{z}}[/tex]
4. When using the del operator, it will often be necessary to remember that in non-Cartesian coordinate systems, the normal vectors will be non-constant functions of the variables themselves.
Use the chain rule. Given a function f(x,y,z), the "del" or "grad" is
[itex]\frac{\partial f}{\partial x}\vec{i}+ \frac{\partial f}{\partial y}\vec{j}+ \frac{\partial f}{\partial z}\vec{k}[/itex]
in Cartesian coordinates.
In cylindrical coordinates,
[tex]\frac{\partial f}{\partial x}= \frac{\partial f}{\partial r}\frac{\partial r}\frac{\partial r}{\partial x}+ \frac{\partial f}{\partial \theta}\frac{\partial \theta}{\partial x}+ \frac{\partial f}{\partial z}\frac{\partial z}{\partial x}[/tex]
[itex]r= \sqrt{x^2+ y^2}= (x^2+ y^2)^{1/2}[/itex] so [itex]\frac{\partial r}{\partial x}= (1/2)(x^2+ y^2)^{-1/2}(2x)[/itex][itex]= \frac{x}{\sqrt{x^2+ y^2}}= \frac{r cos(\theta)}{r}= cos(\theta)[/itex]
[itex]\theta= arctan(\frac{y}{x})[/itex] so [itex]\frac{\partial \theta}{\partial x}= \frac{1}{1+ \frac{y^2}{x^2}}\frac{-y}{x^2}[/itex][itex]= \frac{-y}{x^2+ y^2}= \frac{-r sin(\theta)}{r^2}= -\frac{1}{r}sin(\theta)[/itex].
Of course, since x, y, and z are independent variables, of course [itex]\frac{\partial z}{\partial x}= 0[/itex].
So [itex]\frac{\partial f}{\partial x}= cos(\theta)\frac{\partial f}{\partial r}- \frac{1}{r}sin(\theta)\frac{\partial f}{\partial \theta}[/itex]
and similarly for [itex]\frac{\partial f}{\partial y}[/itex]. [itex]\frac{\partial f}{\partial z}[/itex] is the same in cylidrical coordinates.
Here, I have left the vector in the [itex]\vec{i}[/itex], [itex]\vec{j}[/itex], and [itex]\vec{k}[/itex] basis. Arildno put them in terms of vectors in the "r" and "[itex]\theta[/itex]" directions.
HallsofIvy has given you a detailed derivation of a specific case of transformation.
In order to prove the general result (i.e, what I gave you without any proof), it would be necessary to make a generalization out of HallsofIvy's proof for the special case.
Okay, so you transform from F(x,y,z) to f(r,θ,z), and grad f is simply i ∂f/∂x + j ∂f/∂y + k ∂f/∂z, using chain rule to compute the partial derivatives?
I'm not following this part. How do you switch between the two bases?
Correct.
We have:
[tex]\vec{i}_{r}=\cos\theta\vec{i}+\sin\theta\vec{j},\vec{i}_{\theta}=-\sin\theta\vec{i}+\cos\theta\vec{j}[/tex]
Inverting this, we get the useful relations:
[tex]\vec{i}=\cos\theta\vec{i}_{r}-\sin\theta\vec{i}_{\theta}[/tex]
[tex]\vec{j}=\sin\theta\vec{i}_{r}+\cos\theta\vec{i}_{\theta}[/tex]
arildno said:
Correct.
We have:
In accordance with HallsofIvy's post, we therefore get:
[tex]\frac{\partial{F}}{\partial{x}}\vec{i}+\frac{\partial{F}}{\partial{y}}\vec{j}=(\frac{\partial{f}}{\partial{r}}\frac{\partial{r}}{\partial{x}}+\frac{\partial{f}}{\partial\theta}\frac{\partial\theta}{\partial{x}})(\cos\theta\vec{i}_{r}-\sin\theta\vec{i}_{\theta})+(\frac{\partial{f}}{\partial{r}}\frac{\partial{r}}{\partial{y}}+\frac{\partial{f}}{\partial\theta}\frac{\partial\theta}{\partial{y}})(\sin\theta\vec{i}_{r}+\cos\theta\vec{i}_{\theta})[/tex]
Substituting, we get:
[tex]=(\frac{\partial{f}}{\partial{r}}\cos\theta-\frac{\partial{f}}{\partial\theta}\frac{\sin\theta}{r})(\cos\theta\vec{i}_{r}-\sin\theta\vec{i}_{\theta})+(\frac{\partial{f}}{\partial{r}}\sin\theta+\frac{\partial{f}}{\partial\theta}\frac{\cos\theta}{r})(\sin\theta\vec{i}_{r}+\cos\theta\vec{i}_{\theta})[/tex]
Simplify and rearrange that expression to get the planar components of the gradient in cylindrical co-ordinates (the vertical component is, of course, unchanged).
Thanks a lot to both of you.
What I was confused about is switching bases in the general case. In cylindrical coordinates its easier to see it geometrically, but in the general case its not always obvious; so I was wondering if there is a technique for solving the problem with other transforms. Maybe its too difficult and I should stick to simpler problems, I don't know.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 23 ·
  • · Replies 40 ·
