New Reply
ac circuit non inductive resistor and a coil..
Share Thread
Jan29-11, 02:17 AM   #1
A non inductive resistor takes 8A at 100 volts. What inductance of a coil of negligible resistance must be connected in series in order that this load can be supplied from a 220 volt 60 Hz mains.
2. Relevant equations
Z^2 = R^2 + XL^2
R=V/I
XL = 2pi(frequency) L(inductance)
3. The attempt at a solution
i have solve the resistance before the coil is added.. R=12.5 ohms....
i am stuck on how to get the value of the coil since there is no given current..
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan29-11, 02:40 AM   #2
(Stipud educators. The correct answer to this question is that any finite inductance will "supply" the load!!)
The implied question phrased in more than half-witted manner is, "What will supply the load at the same RMS current?
You know the new voltage. It's 220 VAC. So it's not the same one you used to find R.
Use the voltage divider rule for complex impedance in series. Remember the one for finding the voltage across one resistor that's in series with a second resistor? It looks the same.
New Reply
Similar discussions for: ac circuit non inductive resistor and a coil..
Thread Forum Replies
two resistor RC circuit Introductory Physics Homework 6
Resistor, capacitor and coil with Alternating current Introductory Physics Homework 2
Resistor in circuit Introductory Physics Homework 3
Induction Coil powering a load (inductive reactance problem) Electrical Engineering 23
Unwanted signal in an op-amp circuit (inductive pickup?) Electrical Engineering 7
