Check Valves: Questions Answered
  • Thread starter Thread starter RKD89
    Doubts Valve
Check valves open when the pressure exceeds their cracking pressure, allowing gas transfer until the pressure drops below this threshold or the pressures equalize. The duration the valve remains open depends on the pressure dynamics in both vessels. Check valves can be adjusted to operate within specific pressure ranges, with options available from manufacturers like Swagelok. However, check valves may not seal perfectly upon closing, leading to potential leakage if contact stress on the seat is insufficient. Understanding the forces acting on the valve components is crucial for determining their operational characteristics.
RKD89
http://en.wikipedia.org/wiki/Check_valve
from the above wiki link I have understood basic concepts on Check Valves
Suppose I Heat a gas ( air ) in a closed vessel.
It's temp and pressure increase. As soon as the pressure reaches ( or exceeds??) the cracking pressure , the valve opens and I transfer the heated gas to another vessel ( at a lower pressure and temp)
For How long will the Valve remain open
1: Till the pressure in the heated vessel drops below the Cracking pressure
or
2:Till the pressure in both the vessels is evened out ( ie the valve closes to prevent back flow)
Also are valves available that can be adjusted to work on different ( a small range of say 30-35 psi) pressures
A check valve will close when the forces acting on the poppet or closing device (swing checks) equilabrate. Forces on the poppet forcing it open include the pressure times a differential area and possibly gravity. Forces closing include the spring load and possibly gravity. You can do a free body diagram on the valving element to determine what pressure it opens or closes at. Generally, the opening and closing value is the same.
Check valves don't always seal up well on closing though. Like any valve, as the contact stress on the seat drops off, leakage occurs. The sealing surfaces might be in contact over most of the area, but leakage through the seat will occur if there's insufficient contact.
There are valves that can be adjusted over the range you need. Swagelok for example has http://www.swagelok.com/search/find...-1&item=c80b8fbe-343c-49a5-8ef1-2a086c6523b7", but I'm sure there are many others. Might want to do a search on adjustable checks.
thnx...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
