Calculating Resistance in a Light Bulb
To calculate the resistance of a 90-watt light bulb connected to a 120V rms voltage, the formula used is R = V²/P. Substituting the values, R equals 160 ohms. An initial calculation incorrectly resulted in 0.00625 ohms due to algebraic errors. The correct resistance value is confirmed as 160 ohms. Accurate calculations are essential for understanding electrical properties.
Xels
A "90-watt" light bulb uses an average power of 90W when connected to an rms voltage of 120V .
What is the resistance of the lightbulb?
Pav=(V2rms/R)
90W = 120V2/R
90W/120V2 = R
R = .00625\Omega
You have an algebra problem with your solving for R.
Hrmm...
P = V2/R
PR = V2
R = V2/P
R = 160\Omega
That works better huh? Thank you!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
