How does the ideal gas law work?
The ideal gas law, represented by the equation PV = nRT, illustrates the relationship between pressure, volume, temperature, and the number of moles of gas. When a gas expands at constant pressure, the average kinetic energy of the gas molecules increases due to the need for more forceful collisions with the container walls, necessitating an input of heat energy. Conversely, if the pressure decreases sufficiently, the gas can expand while losing temperature, resulting in a decrease in kinetic energy as the gas performs work on the environment, such as pushing a piston. Understanding these dynamics is crucial for applications involving gas behavior in thermodynamics.
  • Understanding of the ideal gas law (PV = nRT)
  • Basic knowledge of kinetic energy and temperature relationships
  • Familiarity with concepts of pressure and volume in gases
  • Knowledge of thermodynamic work and energy transfer
  • Study the derivation and applications of the ideal gas law in real-world scenarios
  • Explore the principles of thermodynamics, focusing on work done by gases
  • Learn about the relationship between temperature, pressure, and volume in different gas laws
  • Investigate the effects of heat transfer on gas expansion and contraction
Students and professionals in physics, chemistry, and engineering, particularly those interested in thermodynamics and gas behavior in various applications.
pelmel92
So here's what has me all confuzzled about the relationship between temperature and pressure:
Temperature is proportionate to average kinetic energy... but why does expanding a container lower the KEavg of the container's gaseous contents? Shouldn't the conservation of momentum keep all the particles moving along at the same average velocity? What exactly is slowing them down, or in the case of reduced container volume, speeding them up?
Chemistry news on Phys.org
Since PV = nRT, if you expand a container without changing the pressure or number of moles of gas, the average kinetic energy of the gas molecules will increase, not decrease.
This makes sense when you consider the requirement for constant pressure. To maintain a constant pressure, the gas molecules must exert the same force per unit area against the walls of the container. However, if the gas expands and the number of moles of gas remain the same, collisions with the walls of the container will be less frequent (in part because you've increased the area of the container). Therefore, to maintain the same pressure, these collisions must be more forceful, requiring the gas molecules to have a higher kinetic energy. Expanding a gas at constant pressure therefore requires an input of heat energy into the gas.
Now, this refers to just one way of making a gas expand. There are many other ways to make a gas expand. For example, it is possible to make a gas expand and decrease its temperature if you decrease the pressure enough. As you note, however, a decrease in temperature means a decrease in the kinetic energy of the gas. Where does that lost kinetic energy go? In this case, the expanding gas is performing work on the environment (imagine an expanding gas pushing a piston against a load). Therefore, the "lost" kinetic energy is really being used to perform work.
  • · Replies 17 ·
