The relation between incompressibility and divergence-free?
  • Thread starter Thread starter phdggg
    Relation
Incompressibility in fluids is directly related to a divergence-free condition, meaning that for fluids, divergence-free implies incompressibility in all cases. For solids, the relationship is more complex; while small deformations can be characterized by a divergence-free vector field, large deformations complicate this due to the requirement that the determinant of the deformation gradient equals one. This indicates that incompressibility in solids may not strictly adhere to the divergence-free condition under large deformations. Therefore, while divergence-free is a clear indicator of incompressibility in fluids, the same cannot be universally applied to solids without considering deformation scale. Understanding these distinctions is crucial for accurate modeling in finite element analysis.
phdggg
Hi all,
One thing I am really confused is the relation between incompressiblity and divergence-free. Since I am coding a finite element code that use mixed displacement and pressure formulation. From what I got from your book. Both incompressible solid and fluid can be characterized by divergence-free vector field (displacement for solid and velocity for fluid). But is this only for small deformation in the case of solid? Since for large deformation, the determinant of deformation gradient must be one, which seems not equivalent to divergence-free.
What about for fluid, because it uses Eularian frame, the divergence-free should be equivalent to incompressibility for any case. Is this correct? Thanks in advance for your clarification!
Mengda
You are correct.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
