Voltage vs Potential Energy Formulas
The discussion centers on the confusion surrounding the signs in the formulas for voltage (V) and potential energy (U) in electric fields, particularly in the context of a parallel plate capacitor. The user grapples with why the calculated potential difference (ΔV) results in a negative value, despite deriving a positive expression using the relationship ΔV = EΔr. Clarifications reveal that electric potential is defined as the negative integral of the electric field, leading to the conclusion that the potential difference from the negative to the positive plate must be positive, despite the negative work done by the electric field. The conversation emphasizes the importance of correctly applying calculus and understanding the conventions of electric potential and energy. Ultimately, the resolution highlights that the textbook's positive capacitance equation aligns with the established definitions and conventions in electrostatics.
[V]
I am having a hard time figuring out the signs for some of these formulas:
First of all, U=Potential Energy
V=\frac{U}{q}
\int F dr = \int Eq dr = - Work
Since,
Work=K=-U
Therefore
\int Eq dr=+U
U=\frac{QqK}{r}
Therefore,
V=\frac{KQ}{r}
BOTH U & V have a positive slope of 1/r.
So far, everything checks out. But when I want to find the ΔV across a distance of a parallel plate capacitor, something seems to break down...
\int E dr = V
Since E is constant here:
E\int dr = V
I take the derivative WRT to 'r'
E=\frac{dv}{dr}
dV=E * dr
What is the potential difference between 20cm and 40cm in the uniform 3000 (V/m) electric field?
The answer is -600V. I don't fully understand why it is negative!
The equation I just drived, ΔV=EΔr gives me a positive value!
How do you justify this negative number in the end? Please explain with calculus terminology if possible.
Are all my assumptions up until this point correct?
Hi [V]! :smile:
You've lost a minus …
U = -Qqk/r (= ∫-∞r Qqk/x2 dx) :wink:
Ahh! Cant be!
\int_i^f F dr = (-\frac{KQq}{r_{f}})-(-\frac{KQq}{r_{fi}})
W=-(\frac{KQq}{r_{f}}-\frac{KQq}{r_{fi}})
\Delta U=-W
\Delta U=\frac{KQq}{r_{f}}-\frac{KQq}{r_{fi}}
U=\frac{KQq}{r}
Correct?
Hi [V]! :smile:
Sorry, you're right, I was getting confused with gravitational potential. :redface:
The error was in your equation …
[V];3199483 said:
\int E dr = V
… potential energy = minus work done by a conservative force
electric potential = minus work done per charge
so V = -∫ E dr :wink:
Thank you! :)
Soo
V = -\int E dr
If I derive both sides, I get
\frac{dV}{dr}=-E
E=\frac{-\Delta V}{\Delta r}
With this equation, my other problem seems to work.
However, now this presents another problem!
Using this relation, I want to find the Capacitance of a parallel plate capacitor.
Given that
E=\frac{Q}{\epsilon_0A}
And
C=\frac{Q}{\Delta V}
Therefore, using the relation I just proved in the previous stepped:
\frac{-\Delta V}{\Delta r} = \frac{Q}{\epsilon_0A}
Solve for Q
Q=-\frac{\epsilon_0A\Delta V}{\Delta r}
C=\frac{Q}{\Delta V}=-\frac{\epsilon_0A}{\Delta r}
then just replace variables to match my literature...
C=-\frac{\epsilon_0A}{d}
But Waiit!
My textbook says it is positive!
They seem to be using this relationship to derive this equation:
E=\frac{\Delta V}{d}
They use different variables, but why is it positive? I thought I just proved earlier that it should be :
E=-\frac{\Delta V}{d}
hi [V]! :smile:
[V];3200429 said:
Using this relation, I want to find the Capacitance of a parallel plate capacitor …
let's measure all displacements from the -ve to the +ve plate …
then D and E are negative, D = -Q/A, E = -Q/ε0A …
the potential difference from the -ve to the +ve plate is V = -∫ E.dx = ∫ Q/ε0A dx = xQ/ε0A
(to put it in more general terms, E goes from +ve to -ve, so the work done from the -ve to the +ve plate must be negative, and the potential difference must be positive)
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
