Adjusting LM555 timer frequency
  • Thread starter Thread starter bob987
    Frequency Timer
The frequency of the LM555 timer circuit is primarily determined by the 33K resistor and the 10uF capacitor, with increasing either component slowing the flash rate. For precise calculations, it's recommended to consult a 555 timer specification sheet or application note, which typically includes timing equations and graphs. Engaging with other forum users who are working on similar LED flasher projects can also provide additional insights. Sharing the relevant schematic with them may facilitate further assistance. Understanding these components is crucial for achieving the desired flashing frequency.
bob987
I found the following circuit http://www.555-timer-circuits.com/bi-polar-led-driver.html that suits the task I am trying to achieve. My only issue is I don't know what the frequency would be or how to change it. Is the frequency determined by the cpacitor and the 33K resistor or is it more complex. Any help would be appreciated. Thanks for your time.
Yes the 33K resistor and 10uF capacitor set the flash rate. Increasing either will slow the flashes.
Find a 555 spec sheet or application note online. They usually have an extensive section about calculating the timing, and some convenient graphs that will get you into the ball-park.
Also look at this forum and find the other folks who are trying to make led flashers and send them that schematic...I've reached my 555 answer limit for the week...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
