Disconnect between Lennard-Jones and Heat of Vaporization
The discussion centers on the relationship between the heat of vaporization and molecular interactions during evaporation. It questions how breaking bonds can lead to a decrease in translational kinetic energy, noting that while escaping molecules lose energy, the cooling effect on the remaining liquid is not directly explained. The analysis reveals that, according to Lennard-Jones potential models, water molecules have sufficient kinetic energy to escape their neighbors, suggesting that evaporation should occur more rapidly than observed. However, the significant role of hydrogen bonding in water complicates this, as it requires more energy to overcome these interactions than the Lennard-Jones model accounts for. Ultimately, the conversation highlights the need to consider additional factors, such as dipole-dipole interactions, to fully understand the evaporation process in water.
FireBones
I'm trying to understanding "Heat of Vaporization" in fundamental terms.
People say that processes like evaporation and boiling are endothermic because chemical bonds are being broken, but for actual cooling to occur there must a loss in translational kinetic energy of the molecules involved. So I'm asking myself "how can the breaking of bonds lead to a decrease in molecular (translational) kinetic energy?"
The obvious answer is that neighboring molecules slow down a molecule as it is escaping a liquid. This means energy is lost by the system as a whole. This does not explain directly how evaporation cools water (since the energy being lost is lost by the escaping molecule, not the molecules left behind), but it at least explains how a closed system can be cooled by evaporation/boiling going on inside it.
One could also argue that the molecules that escape are, on average, the faster moving molecules, so the average kinetic energy of the sample goes down because in the process of phase change it is losing its "hotter" particles.
With these notions in mind, I decided to look at the question of "how much energy is actually lost when a molecule escapes?" In other words, how much does the tugging by nearby molecules slow down an escapee? That is when I got very confused.
I looked at typical water simulation models, and it appears that it is far easier to escape nearby molecules than I had thought. Taking the Lennard-Jones as a rough approximation, the potential well formed by a pair of molecules has a depth of about 650 J/mole. If we mentally put 3 neighbors around the molecule, it would seem that the amount of energy necessary for water molecules to escape their neighbors is only about 2kJ/mole, which is well below the enthalpy of vaporization [40 kJ/mole].
In fact, the average water molecule at any temperature [0C to 100C] has more than enough kinetic energy to escape its neighbors according to the L-J model. Even taking into consideration issues like direction of motion, etc., one would expect an unsettling percentage of molecules (about 25 percent) on the surface of a puddle at room temperature to be moving in the right direction and with sufficient momentum to escape at every nanosecond.
Something is not adding up here.
Could someone explain to me:
A. Why is the depth of the L-J potential such a tiny fraction of the energy of vaporization?
B. Why don't puddles evaporate into dry air practically instantaneously since about a quarter of the molecules on their surface at any given instant are moving fast enough and in the right direction to escape from their L-J potential wells?
Thanks
Chemistry news on Phys.org
Nevermind. The L-J potential does not include hydrogen bonds.
I think you are correct, it is just that you have calculated the evaporation of helium or a similar noble gas. Water is much more difficult since the interation is dominated by hydrogen bonds. It would be interesting to see if you can get it right if you include the dipole dipole interactions too. The dipole moment of water is probably easy to find.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
