MATLAB Implementing Particle Filter with Matlab
The discussion revolves around the implementation of a Regularized Particle Filter (RPF) in Matlab, highlighting issues with weight calculations during particle filtering. The user describes their approach to particle propagation and weight normalization, noting that the weight calculation often results in values close to zero, leading to NaN values during normalization. This issue also appears in the Sequential Importance Resampling (SIR) particle filter, but is masked by the resampling step that resets weights. The user seeks guidance on potential flaws in their RPF implementation and solutions to the weight calculation problem. Additionally, there is a request for clarification regarding the generation of the epsilon variable from a Gaussian kernel, indicating a need for a better understanding of this step in the algorithm.
manchung214
I'm now implementing different kinds of Particle Filters using Matlab. One is the Regularized Particle Filter(RPF) and my code for 1 time-step filtering is as follows:
function [xcap,wcap]=RPF(x,z,k,N_thre,Q)
N=size(x,1); %no. of particles
m=size(x,2); %dimension of state space
xcap=zeros(N,1);
wcap=zeros(N,1);
%Particle Propagation
for i=1:N
xcap(i)=draw_px(x(i),k,Q);
wcap(i)=pz(z,xcap(i));
end
%Normalizing Weights
t=sum(wcap);
wcap=wcap./t;
N_eff=1/(sum(wcap.^2)); %Calculating Effective Sample Size
if (N_eff<N_thre)
S=emp_cov(xcap,wcap); %empirical covariance matrix
L=chol(S,'lower'); %the square root matrix of S
[xcap,wcap,~]=resample(xcap,wcap);
epsilon=zeros(N,m);
A=(4/(m+2))^(1/(m+4));
h=A*(N^(-1/(m+4)));
for i=1:N
epsilon(i)=(h*L)*randn(1,m);
xcap(i)=xcap(i)+h.*(L*(epsilon(i)'))';
end
end
In my experiment, I use the typical nonlinear system:
x(k)=0.5*x(k-1) + (25*x(k-1)/(1+x(k-1)^2)) + 8*cos(1.2(k-1)) + w(k)
and the measurement equation is:
z(k)=(x(k)^2)/20 + v(k)
where w and v are both zero-mean, white and Gaussian with variance Q and 1 respectively.
The function draw_px is used for sampling from the distribution p(x(k)|x(k-1)) and the function pz is used for calculating p(z(k)|x(k)).
My problem is that when calculating the weights, wcap, of the particles, pz often returns a number so close to 0 that computer recognizes it as 0. And sometimes, all the wcap(i)'s become 0 and in the normalizing step, wcap=wcap./t returns NaN because the sum t is 0.
Actually, the same problem occurs when implementing SIR particle filter. But in the SIR particle filter, resampling step is always performed and the weights will all be reset to 1/N after resampling step and hence the problem is hidden.
Is there anything wrong with my implementation of the RPF? If no, how could I fix the above problem?
Thank you!
hello , i d ont understand this step epsilon(i)=(h*L)*randn(1,m);
how to draw from epsilon from the gaussian kernel
