| New Reply |
please help calculate the metacentric height pontoon |
Share Thread | Thread Tools |
| Apr11-11, 04:10 AM | #1 |
The plan view of a flat bottomed pontoon with all its sides vertical 12m long with 1m radius at each end and 2m wide.The displacement including the load is 28tons. It is used in sea water for which the relative density can be taken as 1.025. a)The metacentric height if the mass centre of the load is 400mm above the base. b)If part of the load having a mass of 1.2tons is to be moved 500mm to one side of centre, calculate the expected list this would cause. 2. Relevant equations H=Wx X1/w+Wc tan Teta 3. The attempt at a solution |
| Apr14-11, 04:14 PM | #2 |
Recognitions:
Do you know how to calculate the initial metacentric height of the pontoon?
| New Reply |
| Thread Tools | |
Similar Threads for: please help calculate the metacentric height pontoon
| Calculate height given KE and mass | Introductory Physics Homework | 3 | ||
| Calculate barrier height | Electrical Engineering | 1 | ||
| calculate the height of a building | Engineering, Comp Sci, & Technology Homework | 8 | ||
| Metacentric height correction due to free surface effect | General Engineering | 2 | ||
