Angular Momentum conserved but not energy?
In summary, the skater has increased her kinetic energy by the square of the distance between her arms and the center of her spinning object.
say_cheese
41
New to the forum- looked through the forum, but all are tangential answers.
A skater with mass m, is spinning with arms extended to radius r1, with a tangential speed v1, angular velocity w1; v1=w1*r1, angular momentum mv1r1 =mw1r12; kinetic energy 1/2 m1v12.
Now she pulls in her arms to a radius r2, r2<r1. Angular momentum is conserved. She changes her tangential speed to v2 and angular velocity to w2.
so mv1r1=mv2r2 or v2 = (v1*r1)/r2
But the new kinetic energy
1/2mv22= 1/2mv12*(r1/r2)2
Since r1>r2, kinetic energy has increased by the square of (r1/r2). Where does this extra energy come from? (there should actually be an energy loss in the intermediate stage, where the skater is spiralling into the new radius). Does the skater have to exert herself?
Yes. Something similar is often done as a demonstration, with someone sitting on a freely rotating stool while holding weights in his outstretched hands. As he brings the weights in closer to his body, his angular velocity increases, and he has to make an effort to "pull the weights in", that is, he has to do work.
The skater must do work to bring her arms in. The extra energy comes from her converting chemical energy in her muscles into mechanical energy.
Exactly!
Thanks guys/girls!
Thanks Guys/Girls!
There's always a 'Force timed Distance' somewhere to explain this sort of thing; it's a matter of spotting it.
When you get down to it, it's that or The Twilight Zone.
1. What is Angular Momentum?
Angular momentum is a measure of an object's rotational motion. It is a vector quantity and is calculated by multiplying an object's moment of inertia by its angular velocity.
2. Is Angular Momentum conserved?
Yes, according to the law of conservation of angular momentum, the total angular momentum of a system remains constant as long as there are no external torques acting on the system.
3. How does Angular Momentum differ from Energy?
Angular momentum and energy are both physical quantities that are conserved in a closed system. However, angular momentum is a measure of rotational motion while energy is a measure of an object's ability to do work or produce heat.
4. Why is Angular Momentum conserved but not energy?
Angular momentum is conserved because there is no external torque acting on a system, meaning the total angular momentum remains constant. However, energy can be transferred between different forms such as kinetic energy and potential energy, causing it to not be conserved in a closed system.
5. How is Angular Momentum conserved in real-life situations?
Angular momentum is conserved in various real-life situations, such as when a figure skater pulls their arms in, causing their rotation to increase. This is because the moment of inertia decreases while the angular velocity increases, resulting in the total angular momentum remaining constant.
  • Mechanics
