Noise from unplugged power supply :S
The discussion revolves around noise issues from a CCD camera's power supply, which persists even when unplugged. The user experiences noise when connecting the power jack and suspects interference from power lines. Suggestions include using shielded wires and grounding the power supply, which led to some improvement when the cable was wrapped in tin foil. Despite these efforts, the noise remains a concern, prompting further inquiries for additional solutions. The conversation highlights the importance of shielding and grounding in reducing electrical noise in sensitive equipment.
Kawakaze
I have a ccd camera that I put a peltier element into, and there is noise from the power supply, even when it isn't plugged in. Just plugging the jack in gives noise, I tried the bypassing thing with a capacitor with no effect. Plugging the PSU in gives no change. I tried moving the power supply around and this makes no difference plugged in or not, any ideas? If the noise is from the power to to camera from the usb port, why would it only appear when i put the jack in? I really am confused with this.
The case is plastic, and i just noticed that when you even touch the 0v pin of the socket for the jack with a metal object, the noise comes back.
It's probably 60/50 Hz noise from power lines, etc. Have you tried using shielded wire from the supply? Is there an Earth ground on the supply? I would think that the project should be in a metal box so as to shied your project as well as the wiring.
You were right, I just wrapped the cable up in tin foil and the noise was almost gone. Shielded cables it is :)
Thanks so much for your help!
I just did some more testing, the noise is much better but it is still too much. Is there anything else to be done? Thanks :)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
