New Reply
Equation of a line that passes through a point.
Share Thread Thread Tools
May21-11, 09:53 PM   #1
Find the equation of the line that passes through A(1,-4, 2) and is parallel to the intersection line of the two planes x - 2y + 3z - 1 = 0 and x - 4y+ 2z - 8 = 0
2. Relevant equations
N/A
3. The attempt at a solution
First I set the first and second equations to [1] and [2]:
x - 2y + 3z - 1 = 0 [1]
x - 4y+ 2z - 8 = 0 [2]
I then multiply [1] by 2 and use elimination to get rid of the y variable for now:
2x - 4y + 6z - 2 = 0
x - 4y + 2z - 8 = 0
________________________
x + 4z + 6 = 0 [3]
I'll then let z = t to solve for x in equation [3]:
x + 4t + 6 = 0
x = -4t - 6
Now I substitute z = t and x = -4t - 6 into equation [1] to solve for y:
-4t - 6 - 2y + 3t - 1 = 0
y = (-1/2)t - 7/2
Now that I have the values of all the unknowns, I first express it in parametric form:
x = -4t - 6
y = (-1/2)t - 7/2
z = t
Knowing this, finally, the direction vector for the line that passes through A(1, -4, 2) can be expressed:
(x,y,z) = (1, -4, 2) + t(-4, 1/2, 1)
I just wanted to know, did I do this correctly? I feel as if I did something wrong. If I did, can you point where I went wrong? Thank you in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
May21-11, 10:30 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Your solution looks fine to me.
May22-11, 07:35 PM   #3
Recognitions:
Another possibly easier way to work this kind of problem is to note that the cross product of the two normal vectors to the planes gives a direction vector for the line. Do you see why?
New Reply
Thread Tools
Similar Threads for: Equation of a line that passes through a point.
Thread Forum Replies
Find equation of the plane that passes through a given point and is perpen. to.... Precalculus Mathematics Homework 1
Line passes through a point parallet to parametric equations Calculus & Beyond Homework 4
Determine point on line where normal passes thr a point intersects the line. Calculus & Beyond Homework 7
If the tangent line to y = f (x) at (9,7) passes through the point (0,6)... Calculus & Beyond Homework 2
Equation of a plane that passes thorugh the line of intersection of...[answer check] Calculus & Beyond Homework 2
