New Reply
Using the Insertion Sort algorithm on a linked list
Share Thread
May22-11, 08:58 AM   #1
Hi there, I wish this wasn't my first post but unfortunately, it is. I will try to contribute later in the semester when my workload is less.
On to the topic, the problem is I have to implement the insertion sort algorithm on a linked list. I have the algorithm for Java (the language we have been taught) that works for an array. Yet for some reason I am having incredible difficulty translating it to a linked list.
I have tried many different styles of implementing this (for example traversing the list iteratively vs recursively) but have gotten frustrated and decided to start from scratch.
Once again I have gotten stuck, so could anyone tell me if I'm even going in the right direction?
Here is my most recent attempt at a solution
public void sort(LList list){
int i, j = 1;
Node toAdd = null;
Node temp = null;
Node curr=null;
for (i = 2; i <= list.length; i++)
temp = list.getNodeAt (i-1);
curr = list.getNodeAt (i);
if (curr.data < temp.data)
list.remove (i);
while (j <= i)
toAdd = list.getNodeAt(j);
if (curr.data <= list.getNodeAt(j).data)
list.add (j-1, curr.data);
list.display (list.firstNode);
System.out.println ();
j++;
It extends a class called LList that I have defined as follows:
public class LList//implements ListInterface
public Node firstNode; // reference to first node
public int length; // number of entries in list
public LList ()
clear ();
} // end default constructor
public final void clear ()
firstNode = null;
length = 0;
} // end clear
public boolean add (int newEntry)
Node newNode = new Node (newEntry);
if (isEmpty ())
firstNode = newNode;
else // add to end of nonempty list
Node lastNode = getNodeAt (length);
lastNode.next = newNode; // make last node reference new node
} // end if
length++;
return true;
} // end add
public boolean add (int newPosition, int newEntry)
boolean isSuccessful = true;
if ((newPosition >= 1) && (newPosition <= length + 1))
if (isEmpty () || (newPosition == 1)) // case 1
newNode.next = firstNode;
else // case 2: list is not empty
// and newPosition > 1
Node nodeBefore = getNodeAt (newPosition - 1);
Node nodeAfter = nodeBefore.next;
newNode.next = nodeAfter;
nodeBefore.next = newNode;
} // end if
length++;
else
isSuccessful = false;
return isSuccessful;
} // end add
public void display (Node firstNode)
Node currentNode = firstNode;
while (currentNode != null)
System.out.println (currentNode.data);
currentNode = currentNode.next;
} // end while
} // end display
public boolean isEmpty ()
boolean result;
if (length == 0)
assert firstNode == null;
result = true;
else
assert firstNode != null;
result = false;
} // end if
return result;
} // end isEmpty
public boolean replace (int givenPosition, int newEntry)
if ((givenPosition >= 1) && (givenPosition <= length))
assert !isEmpty ();
Node desiredNode = getNodeAt (givenPosition);
desiredNode.data = newEntry;
else
} // end replace
public int getEntry (int givenPosition)
int result = 0; // result to return
assert !isEmpty ();
result = getNodeAt (givenPosition).data;
} // end if
return result;
} // end getEntry
public int remove (int givenPosition)
int result; // return value
assert !isEmpty ();
if (givenPosition == 1) // case 1: remove first entry
result = firstNode.data; // save entry to be removed
firstNode = firstNode.next;
else // case 2: givenPosition > 1
Node nodeBefore = getNodeAt (givenPosition - 1);
Node nodeintoRemove = nodeBefore.next;
Node nodeAfter = nodeintoRemove.next;
nodeBefore.next = nodeAfter; // disconnect the node to be removed
result = nodeintoRemove.data; // save entry to be removed
} // end if
length--;
} // end if
return result = 0; // return removed entry, or
// null if operation fails
} // end remove
public boolean isFull () // should ALWAYS return false
return false;
public boolean contains (int anEntry)
boolean found = false;
while (!found && (currentNode != null))
if (anEntry == currentNode.data)
found = true;
else
} // end while
return found;
} // end contains
/** intask: Returns a reference to the node at a given position.
* Precondition: List is not empty; 1 <= givenPosition <= length. */
public Node getNodeAt (int givenPosition)
assert (!isEmpty () && (1 <= givenPosition) && (givenPosition <= length));
// traverse the list to locate the desired node
for (int counter = 1 ; counter < givenPosition ; counter++)
assert currentNode != null;
return currentNode;
} // end getNodeAt
public class Node
public int data; // entry in list
public Node next; // link to next node
public Node (int dataPortion)
data = dataPortion;
next = null;
} // end constructor
public Node (int dataPortion, Node nextNode)
data = dataPortion;
next = nextNode;
public int getData ()
return data;
} // end getData
public void setData (int newData)
data = newData;
} // end setData
public Node getNextNode ()
return next;
} // end getNextNode
public void setNextNode (Node nextNode)
next = nextNode;
} // end setNextNode
public int compareTo (int obj)
int nodeComp;
if (this.data == obj)
nodeComp = 0;
else if (this.data < obj)
nodeComp = -1;
else
nodeComp = 1;
return nodeComp;
} // end Node
Sorry for the lengthy post and thanks for any help,
Dudeface
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
May22-11, 01:23 PM   #2
Mentor
Welcome to Physics Forums!
If you include code in your post, put a [ code ] tag at the start of your code, and a [ /code ] tag at the end (but without the extra spaces). These are HTML tags that preserve your indentation, which makes your code easier to read. I've done that for your code.
Please provide some details about how and where you are stuck. Does your code compile without error? If not, provide us with the compiler error messages. If your code compiles but doesn't run correctly, tell us what it's doing that it shouldn't, or that it's not doing that it should, and any other information that you think might be helpful.
Many of us can look through code and figure out why it isn't working, but that's not the best use of our time.
Quote by dudeface View Post
Code:
    int i, j = 1;
    Node toAdd = null;
    Node temp = null;
    Node curr=null;
        list.remove (i);
        while (j <= i)
          j++;
  public LList ()
    clear ();
    firstNode = null;
    length = 0;
  } // end clear
    if (isEmpty ())
    } // end if
    length++;
    return true;
  } // end add
      } // end if
      length++;
    else
  } // end add
    } // end while
  } // end display
    boolean result;
    if (length == 0)
      result = true;
    else
      result = false;
    } // end if
    return result;
  } // end isEmpty
      assert !isEmpty ();
    else
  } // end replace
      assert !isEmpty ();
    } // end if
    return result;
  } // end getEntry
      assert !isEmpty ();
      } // end if
      length--;
    } // end if
  } // end remove
    return false;
        found = true;
      else
    } // end while
    return found;
  } // end contains
    return currentNode;
  } // end getNodeAt
  public class Node
      data = dataPortion;
      next = null;
      data = dataPortion;
      next = nextNode;
      return data;
    } // end getData
      data = newData;
    } // end setData
      return next;
      next = nextNode;
      int nodeComp;
        nodeComp = 0;
        nodeComp = -1;
      else
        nodeComp = 1;
      return nodeComp;
  } // end Node
Dudeface
New Reply
Tags
insertion sort, java, linked lists
Similar discussions for: Using the Insertion Sort algorithm on a linked list
Thread Forum Replies
What's wrong with my sorted linked list algorithm? (Java) Programming & Comp Sci 6
Linked list Programming & Comp Sci 12
Quicksort/Insertion sort combo Engineering, Comp Sci, & Technology Homework 0
Linked List Programming & Comp Sci 9
linked list help! Programming & Comp Sci 1
