Historical origin of energy momentum equation?
The discussion centers on the historical origin of the energy-momentum relation E² = m²c⁴ + p²c², including inquiries about its first appearance and the contributions of Einstein and others to its formulation. The scope includes historical context, theoretical implications, and references to relevant literature.
  • Historical
  • One participant asks about the original source of the energy-momentum relation and who first posed it.
  • Another participant suggests checking Wikipedia for historical context related to E=mc².
  • Several participants reference specific papers discussing relativistic energy and momentum, noting that while these concepts are present, the exact relation may not be explicitly stated by Einstein.
  • Some participants express uncertainty about the use of "relativistic mass" and its implications for understanding momentum and energy, citing Einstein's own reservations about the concept.
  • There is a discussion about the modern interpretation of the relation m² = E² - p² and its connection to the Poincaré group, with some suggesting that Einstein would disapprove of this interpretation.
  • Participants debate the clarity and utility of introducing velocity-dependent mass terms, with one noting that such terms can lead to confusion in deriving energy and momentum equations.
  • A participant proposes an algebraic method to derive the energy-momentum relation using rest mass and velocity, referencing a pop culture character for emphasis.
Participants express a range of views on the historical context and interpretation of the energy-momentum relation, with no consensus reached on the exact origins or the best approach to understanding the concepts involved.
There are limitations regarding the clarity of definitions, the ambiguity surrounding the concept of relativistic mass, and the historical context of Einstein's writings, which may affect interpretations of the energy-momentum relation.
SamRoss
Does anyone know who first posed the energy relation E2=m2c4+p2c2 and where its original appearance can be found?
You should check
http://www-itp.particle.uni-karlsruhe.de/~schreck/general_relativity_seminar/Zur_Elektrodynamik_bewegter_Koerper.pdf
http://www-itp.particle.uni-karlsruhe.de/~schreck/general_relativity_seminar/Ist_die_Traegheit_eines_Koerpers_von_seinem_Energieinhalt_abhaengig.pdf
Of course this relation follows immediately from the relativistiv energy and momentum - and these have been discussed by Einstein in his first papers - but I don't know whether he explicitly wrote down the relation you are asking for.
tom.stoer said:
You should check
I've read those papers (in English). Relativistic energy is in there although I don't think relativistic momentum is. In any case, do you know a proof that utilizes the two quantities? Most of the proofs that I see depend on the ambiguous relativistic mass.
The modern view is that m² = E² - p² corresponds to the first Casimir of the Poincare group - but Einstein would hate that! So I guess the only (historically correct) way is to deal with the "relativistic mass" which Einstein didn't like, too, as you can see from some remarks like the following one from a 1948 letter to Lincoln Barnett:
"It is not good to introduce the concept of the mass M = m/(1-v²/c²)½ of a body for which no clear definition can be given. It is better to introduce no other mass than 'the rest mass' m. Instead of introducing M, it is better to mention the expression for the momentum and energy of a body in motion."
What do you think Einstein would have said the correct proof was?
Einstein observed that introducing velocity dependend xyz-masses always leads to confusion. Just look at p(v) = mv /(1-v²/c²)½; introducing M(v) = m /(1-v²/c²)½ one can write p(v) = M(v)*v which looks rather familiar; it seems that one can save the Newtonian equation for the momentum p.
But what about E(v); neither the total nor the kinetic energy can be re-written using the same trick. E(v) = M(v)*v^2 / 2 is nonsense, and E = M(v)*c² is correct but does not correspond to any Newtonian formula. So all equations Einstein derived are correct, but using new terms for new, velocity dependend entities does not help.
[tex]E = \frac{m_0 c^2} {\sqrt{1 - v^2/c^2}}[/tex]
[tex]p = \frac{m_0 v} {\sqrt{1 - v^2/c^2}}[/tex]
Use algebra to eliminate v between these two equations. Sheldon Cooper would say, "Easy-peasy." :wink:
  • · Replies 35 ·
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 36 ·
