How to Find Power Series Solutions of Chebyshev's Equation?
Ted123
Chebyshev's Equation is (1-x^2) y^{\prime\prime} - xy^{\prime} + c^2 y =0
where c is a real constant.
(a) Find 2 linearly independent power series solutions of Chebyshev's Equation at x=0: an even one and an odd one.
(b) Hence, using the ratio test, find the radius of convergence for both of these series.
I've manipulated the power series down to:
\sum_{n=0}^{\infty} [(n+2)(n+1)a_{n+2} - n(n-1)a_n - na_n + c^2 a_n ] x^n = 0
which gives the recurrence relation:
a_{n+2} = \frac{n^2 - c^2}{(n+2)(n+1)}a_n
For the even solution:
We have arbitrary a_0
a_2 = -\frac{1}{2} c^2 a_0
a_4 = \frac{4-c}{12} a_2 = - \frac{c^2(4-c^2)}{24} a_0
a_6 = \frac{24-c^2}{30} a_4 = - \frac{c^2(4-c^2)(24-c^2)}{720} a_0
I'm struggling to solve this for a_n ...
For the odd solution:
We have arbitrary a_1
a_3 = \frac{1-c^2}{6} a_1
a_5 = \frac{9-c^2}{20} a_3 = \frac{(9-c^2)(1-c^2)}{120}
I'm also struggling to solve this for a_n ...
I've just re-read the question and it says find the 2 linearly independent power series solutions at x=0.
So does this mean start from y'' + c^2y = 0\;?
In which case:
a_{n+2} = -\frac{c^2}{(n+2)(n+1)}a_n
EVEN:
a_0 arbitrary
a_2 = -\frac{c^2a_0}{2}
a_4 = -\frac{c^2a_2}{(4)(3)} = \frac{c^4a_0}{(4)(3)(2)}
a_6 = -\frac{c^2a_4}{(6)(5)} = -\frac{c^6a_0}{(6)(5)(4)(3)(2)}
ODD:
a_1 arbitrary
a_3 = -\frac{c^2a_1}{(3)(2)}
a_5 = -\frac{c^2a_3}{(5)(4)} = \frac{c^4a_1}{(5)(4)(3)(2)}
a_7 = -\frac{c^2a_5}{(7)(6)} = -\frac{c^6a_1}{(7)(6)(5)(4)(3)(2)}
So... it seems:
\displaystyle a_{2n} = (-1)^{n} \frac{c^{2n} a_0}{(2n)!}
\displaystyle a_{2n+1} = (-1)^{n} \frac{c^{2n}a_1}{(2n+1)!}
So it looks like the 2 linearly independent power series solutions (even and odd respectively) are?:
\displaystyle a_0 \sum_{n=0}^{\infty} (-1)^{n} \frac{c^{2n}}{(2n)!} x^{2n}
\displaystyle a_1 \sum_{n=0}^{\infty} (-1)^{n} \frac{c^{2n}}{(2n+1)!} x^{2n+1}
Your first interpretation of the problem is correct. The series will have terms of the form an(x-x0)n. The problem is telling you x0=0.
You made one minor error: for a6, you should have (16-c2) instead of (24-c2) in the numerator.
I think the best you'll be able to do is say
a_{2n} = -\frac{c^2(4-c^2)\cdots(4(n-1)^2-c^2)}{(2n)!}
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
