DC-HVDC Converter: Full Load & No Load Characteristics
  • Thread starter Thread starter nitsan
    Converter Dc
The discussion focuses on the characteristics of a DC HVDC converter, specifically the difference in output voltage under full load versus no load conditions. It highlights that output voltage typically decreases under load due to internal voltage drops caused by increased current. Regulated power supplies attempt to mitigate this by adjusting the resistance of a series regulator to maintain output voltage. However, even regulated supplies can experience some voltage drop with higher current. Unregulated supplies face additional voltage drops due to capacitor discharge between charging pulses.
nitsan
Hi
I have been using a DC HVDC converter for a project. I am a little confused with the full load and no load characteristics for this kind of converter.The user manual states that at full load "X" Volts of input gives "Y1" volts output and for no load that same input voltage gives "Y2" volts output with Y2>Y1 by a couple of %. Why does this happen?
thanks
Do you mean: "why is the output lower on load than on no-load"? This is just a measure of how good the regulation of the power supply is.
The output voltage of almost all power supplies drops with load because the extra current causes voltage drops inside the power supply.
Regulated power supplies correct for this by monitoring the output and reducing the resistance of a series regulator in the power supply to increase the output voltage when an increased load would otherwise cause the voltage to drop.
Even these power supplies can have some voltage drop with increasing current.
In unregulated power supplies, the drop in voltage is partly due to the capacitor being partly discharged between charging pulses from the rectifier.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
