New Reply
Finding electric field/displacement current for time-varying current in coaxial cable
Share Thread Thread Tools
Jun11-11, 10:12 PM   #1
An alternating current [itex]I = I_0 \cos(\omega t)[/itex] flows down a long straight wire and returns along a coaxial tube of radius [itex]a[/itex].
  1. By constructing an appropriate Amperian loop or otherwise, and assuming that the induced electric field E goes to zero as the distance from the wire, [itex]s[/itex], becomes large, find [itex]{\bf{E}}(s,t)[/itex].
  2. Find the displacement current density, [itex]\bf{J_D}[/itex], and hence the total displacement current, [itex]I_D[/itex].
2. Relevant equations
[tex]\nabla\times{\bf{E}} = -\frac{\partial{\bf{B}}}{\partial t}[/tex]
[tex]\nabla\times{\bf{B}} = \mu_0{\bf{J}} + \mu_0\epsilon_0\frac{\partial{\bf{E}}}{\partial t}[/tex]
[tex]\oint_C{\bf{E}}\cdot\,d{\bf{\ell}} = -\frac{\partial}{\partial t} \int_S {\bf{B}}\cdot\,d{\bf{a}}[/tex]
[tex]\oint_C{\bf{B}}\cdot\,d{\bf{\ell}} = \mu_0 I_{enc} + \mu_0\epsilon_0\frac{\partial}{\partial t}\int_S {\bf{E}}\cdot\,d{\bf{a}}[/tex]
3. The attempt at a solution
Just to clarify, I believe the current in the coaxial tube is the negative of the current through the central wire.
The fact that you're asked to compute displacement current in the second part of the question should mean that you can calculate E solely using Maxwell-Faraday, and once you have E it ought to be fairly straightforward to calculate B using Ampere's law.
The time derivative of B ought to look something like [itex]\sin(\omega t)[/itex] (diminishing with increasing s, so something like a [itex]\frac{1}{s}[/itex] or [itex]\frac{1}{s^2}[/itex] factor thrown in as well), but I'm not sure if I should replace [itex]t[/itex] with [itex]t-\frac{s}{c}[/itex] (and possibly [itex]t-\left(\frac{s-a}{c}\right)[/itex]) to account for the time to propagate. In that case, because of the difference in distance from the wire and the tube, there should always be some B-field outside the tube (if the currents were constant and opposite forever, then B would of course be 0 for s>a).
I think the electric field runs parallel to the current, and it is constant at some time t for a fixed distance from the axis. If there is a B-field outside the tube, varying with time, then the electric field outside the tube is not constant through time. The appropriate Amperian loop to apply the Maxwell-Faraday law is a rectangle with two sides parallel to the axis. This would give:
[tex]\oint_C{\bf{E}}\cdot\,d{\bf{\ell}} = {\bf{E}}(s_2,t)h - {\bf{E}}(s_1,t)h = \iint_S \frac{\partial{\bf{B}}}{\partial t} \cdot\,d{\bf{a}} = \int^{s_2}_{s_1}\int^h_0\frac{\partial{\bf{B}}}{\partial \,t} \,ds\,dz[/tex]
Where h cancels because there is no z-dependence. The problem is that I can't figure out how to get something that goes to 0 as [itex]s\rightarrow\infty[/itex]. At one point I ended up trying to integrate something like [itex]\frac{1}{s}\sin\left(\omega\left(t-\frac{s}{c}\right)\right)[/itex], and that seems to give the incomplete gamma function in its result, so that can't possibly be right. I'm completely lost, but I'm certain that the answer is simpler than I'm trying to make it.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
New Reply
Tags
ampere's law, displacement current, electromagnetism
Thread Tools
Similar Threads for: Finding electric field/displacement current for time-varying current in coaxial cable
Thread Forum Replies
Finding electric field intensity, power, current given current density Advanced Physics Homework 0
Coaxial cable; current problem Introductory Physics Homework 3
Magnetic and electric field between current carrying coaxial cables Introductory Physics Homework 1
Electric field in coaxial cable Advanced Physics Homework 1
E-field from Time Varying B-field of Current Loop Classical Physics 4
