Creating a magnetic ring field question
  • Context: Undergrad
  • Thread starter Thread starter oliver102
    Field Magnetic Ring
The discussion revolves around the feasibility of creating a magnetic suspension field capable of holding magnetic objects in mid-air. Participants explore various designs, materials, and theoretical limitations related to magnetic fields and suspension techniques.
  • One participant proposes creating a magnetic ring field using neodymium rod magnets arranged in a specific pattern to hold objects in place against gravity.
  • Another participant asserts that such a magnetic suspension cannot be achieved without using diamagnetic materials or superconductors, referencing a theorem that supports this claim.
  • A request for suggestions on suitable diamagnetic materials is made, with a mention of graphite as a potential candidate for suspension in a magnetic field.
  • It is suggested that a type-II superconductor could work without a ring due to flux pinning, although practical challenges such as cooling requirements are noted.
  • One participant proposes an alternative design where magnets are arranged to form a "cup" to support an object, but this idea is challenged based on Earnshaw's theorem, which states that stable configurations cannot be achieved with static magnetic fields.
  • A later reply suggests using varying magnetic fields or additional support to hold the object in place, indicating a shift in approach after considering the limitations of static configurations.
Participants express disagreement regarding the feasibility of the proposed magnetic suspension methods, with some asserting that it is impossible to achieve stable configurations using static magnetic fields, while others explore alternative designs and materials.
Limitations include the dependence on specific materials and configurations, as well as unresolved questions about the practical implementation of proposed designs and the theoretical implications of Earnshaw's theorem.
oliver102
Hi there,
I'm attempting a science experiment to create a magnetic suspension field that can hold magnetic objects in place in mid air.
Since a Magnetic field isn't flat a single magnet would be pointless as the opposing object is continually sliding off it, so I looked at creating a ring field so that objects would get caught in a magnetic trap as gravity acted down on them.
I'm wanting to build a large one that can hold something substantial however I want to build a prototype first to make sure my little theory works.
The design for it is relatively simplistic, a disk of wood with a uniform sequence of holes in 3 rings going round it.
The magnets them selfs are neodymium rod magnets dropped into the housings so they are fixed, each one is 2mm wide and 8 mm long. I'm still calculating the spacing in order to generate the magnetic ring needed to apply 360 degree's of magnetic force to be able to hold something stationry as I know a single weak spot will cause it to collapse.
Anyone have any thoughts on improving this little experiment?
I studied maths not physics, magnetic fields are just something that fascinate me and I'd like to do some experiments with their applications.
Thanks
It can't be done (unless you use a diamagnetic materials, such as superconductors).
There is even a theorem proving this: "[URL
Can you suggest a Diamagnetic material that would work?
Just so I understand it, a common permanent magnetic field can support a diamagnetic plate can't it? Such as graphite, if dropped in a magnetic field should be suspended.
I only did a few weeks of electromechanics and didn't get to do much practical work to experiment.
The only thing that would work is a superconductor; and if you use a type-II superconductor such as YBCO you don't even need a ring (due to the flux pinning).
But then you would of course need to cool it using for example liquid nitrogen or a pulse tube cooler so it is rarely a practical solution.
All normal diamagnetic materials are much too weak to support anything in the kinds of fields you can get from a permanent magnet.
Hence, there is a reason why you've never seen this in a commercial product.
Could you simply design it so that the magnets holding the object up are on the bottom and it sits in the well of a couple of others on the ground? Like have a center magnet on a base, with a couple of other magnets arranged around it but tilted inwards slightly so that the fields form a "cup" of sorts. Would this work?
No, see Earnshaw's theorem above. It is quite literally impossible to create configuration where the object is stable.
Ah ok, I see now. New suggestion: Use some kind of support or varying magnetic fields to hold it in place.
  • · Replies 42 ·
16K
  • · Replies 22 ·
  • · Replies 20 ·
