| New Reply |
Otto Cycle: net work done |
Share Thread | Thread Tools |
| Jun18-11, 08:49 PM | #1 |
Show that the net work done by the otto engine per cycle is Cv(Tc - Tb)(1 - Ta/Tb) PV diagram: ![]() 2. Relevant equations Work done by a kmole of gas expanding irreversibly and adiabatically from P1 V1 T1 to P2 V2 T2: = (P1V1 - P2V2)/(γ - 1) = R(T1 - T2)/(γ - 1) 3. The attempt at a solution The only work done by the otto engine is during the adiabatic expansions/compressions. So the work done by the gas from point A to point B is = R(Ta - Tb)/(γ - 1) Likewise, the work done by the gas from point C to point D is = R(Tc - Td)/(γ - 1) So the net work done by the gas will be = R(Ta - Tb)/(γ - 1) + R(Tc - Td)/(γ - 1) = (R/(γ - 1))(Ta - Tb + Tc - Td) = Cv[(Tc - Tb) + Ta - Td] Here I get stuck. I don't see why the answer doesn't have a Td term. Have I gone wrong somewhere? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Jun18-11, 10:43 PM | #2 |
Recognitions:
AM |
| Jun18-11, 11:19 PM | #3 |
I'm sorry, but I still can't see how to find Td... Your equations seem essentially the same as mine.
| Jun19-11, 10:16 AM | #4 |
Recognitions:
Otto Cycle: net work doneAM |
| Jun21-11, 08:48 PM | #5 |
Recognitions:
What you have to do here is express Td in terms of Ta, Tb and Tc
To do that you must first determine the ratio of Ta to Tb (it depends on the ratio of V1/V2 and gamma). Then determine the ratio of Td to Tc (try to express it in a similar way). Once you do that you will be able to express Td in terms of the other temperatures. For this cycle, the work can be calculated easily using W = Qh-Qc. Since a-b and c-d are adiabatic, heat flows only from b-c and d-a. Since it is isochoric, [itex]\Delta Q_h = nC_v\Delta T_{b-c} \text{ and } \Delta Q_c = nC_v\Delta T_{d-a}[/itex]. AM |
| New Reply |
| Thread Tools | |
Similar Threads for: Otto Cycle: net work done
| Otto Cycle Problem | Introductory Physics Homework | 2 | ||
| Thermodynamics: Otto Cycle | Engineering, Comp Sci, & Technology Homework | 9 | ||
| Otto cycle | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Otto Cycle?? Please help ASAP! | Introductory Physics Homework | 1 | ||
| The Otto Cycle | Classical Physics | 4 | ||
