DC to AC inverter using 555 timer
The discussion focuses on the use of a 555 timer in a DC to AC inverter circuit and the necessity of power amplifiers for higher output. Participants inquire about the specific circuit referenced and the role of the two power amplifiers. It is noted that the 555 timer has limited power capabilities, necessitating additional amplification for effective performance. The lack of a visible schematic complicates the conversation. Understanding the integration of power amplifiers with the 555 timer is crucial for achieving desired output levels in inverter applications.
mfecky
I want to know the function of the two power amplifier ?
What circuit are you referring to?
https://www.physicsforums.com/showthread.php?t=510472
I attached the circuit in this link
Your schematic is not available. The 555 is a relatively low power device, so if you require it to deliver much power output, you need to follow the 555 with a power amplifier.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
