Power transferred to resistance
  • Thread starter Thread starter Tosh5457
    Power Resistance
The average power transferred to a speaker with a resistance of 10.4 Ohms and an additional resistance of 8.20 Ohms in series can be calculated using the formula P = I^2R. The maximum voltage of the AC source is 15.0 V, but to find the average power, one must use the RMS values for voltage and current. The presence of the additional resistance forms a voltage divider, reducing the current through the speaker resistance, which directly affects the power calculation.
  • Understanding of Ohm's Law
  • Knowledge of AC circuit analysis
  • Familiarity with RMS (Root Mean Square) calculations
  • Experience with power calculations in electrical circuits
  • Learn how to calculate RMS values for AC voltage and current
  • Study voltage divider circuits and their applications
  • Explore power transfer in AC circuits
  • Investigate the effects of series and parallel resistances on circuit behavior
Electrical engineering students, hobbyists working with AC circuits, and anyone interested in understanding power transfer in resistive circuits.
Tosh5457
Speaker Resistance = 10.4 Ohm
R = 8.20 Ohm
Maximum voltage of AC source = 15.0 V
What's the average power transferred to the speaker?
P = [itex]I^2R[/itex]
Imax = [itex]I/2^0.5[/itex]
I could the problem if there was only the speaker resistance. I don't understand how the other resistance comes into play or what it does in the circuit.
Hi Tosh5457! :smile:
The extra resistance reduces the current, I. :wink:
The other resistance, in series with the speaker resistance, form a voltage divider. Only a fraction of the supply voltage will appear across the speaker resistance.
You can determine the current through the series connected resistors, then using that current find the voltage developed across the speaker.
Keep in mind that you've been given the maximum voltage of the AC source. To find the average power you'll want the RMS values for voltage and current delivered to the speaker.
  • · Replies 42 ·
