Unit Conversion: How to Find Volts/kRPM for Motor Modeling with 245 RPM/Kv Value
To convert the RPM/Kv value of 245 to Volts/kRPM, it is necessary to interpret the units correctly. The value of 245 RPM/Kv can be converted to 0.245 RPM/V, which, when expressed in kRPM, becomes 0.245(10^-3) kRPM/V. Inverting this gives a value of V/kRPM, resulting in approximately 408 V/kRPM. This high voltage constant suggests that the original unit might actually be kRPM/V rather than RPM/Kv, as typical motors do not operate at such high voltages.
Blues_MTA
For a motor modeling project I am trying to find a value that is measured in Volts/kRPM (Voltage constant) , in the motor specs that I am given i have a value in RPM/Kv,
If the value for RPM/Kv given is 245, how can i find Volts/KRPM, or is that even possible
Thanks!
I assume K means 103
so 245 rpm/kV = 0.245 rpm/V
So now dividing by 1000, 0.245(10-3)krpm/V.
Just invert now to get the units of V/krpm.
So, it would be 1/0.245(10^-3)?
That comes to 408, which is a ridiculously high voltage constant, or at least from what I've seen anyway
My guess is that your second value is in kRPM/V, not RPM/kV. Very few motors run on thousands of volts, so RPM/kV wouldn't make sense as a unit.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
