EM field of dipole derivation from Green's function
The discussion focuses on deriving the electric field generated by a dipole using a Green's function approach. The initial equation for the electric field is presented, and the user seeks clarification on its derivation. It is confirmed that the electric field can be expressed in terms of the dyadic Green's function, which is linked to the scalar Green's function. The conversation highlights the importance of integrating over source currents to relate the electric field to the dipole source, with references to Chew's and Jackson's texts for further study. Overall, the exchange emphasizes the connection between the electric field, dipole moment, and Green's functions in electrodynamics.
krindik
Hi all,
I know that the electric field generated by a dipole is given by
\mathbf{E}= [1-i(\omega/c) r]\frac{3 (\mathbf{p}\cdot\mathbf{r})\mathbf{r}-\mathbf{p} }{r^3}+(\omega/c)^2\frac{\mathbf{p}-(\mathbf{p}\cdot\mathbf{r})\mathbf{r}}{r} e^{i(\omega/c)r}
where \mathbf{p} is the dipole's dipole moment proportional to e^{-i\omega t}.
I'm struggling to find out how this is derived from a Green's function approach. Can somebody help me with this or point me to somebook/reference that shows derivation?
Thanks in advance.
cheers,
Krindik
Some references that deal with deriving the dyadic Green's function are Jackson's "Classical Electrodynamics" and Chew's "Waves and Fields in Inhomogeneous Media."
Hi,
Thanks for the response.
This is what I understood of its derivation. Hope u could clarify.
The electric field due to the dipole can be given by
\mathbf{E}(\mathbf{r}) = k^2 \mathbf{G}(\mathbf{r}, \mathbf{r}')\mathbf{p}(\mathbf{r'}) where \mathbf{G}(\mathbf{r}, \mathbf{r}') is the dyadic Green's functions for the dipole source, which is located at \mathbf{r}' and k is the wave number in the unbounded background.
\mathbf{G}(\mathbf{r}, \mathbf{r}') can be determined from the scalar Green's function G_0(\mathbf{r}, \mathbf{r}') by
\mathbf{G} = \left[\mathbf{I} + \frac{1}{k^2}\nabla \nabla \right]G_0(\mathbf{r}, \mathbf{r}') where \mathbf{I} is the unit dyad, and G_0 = \displaystyle\frac{e^{ik|\mathbf{r}-\mathbf{r}'|}}{|\mathbf{r}-\mathbf{r}'|}.
Is this correct? Really appreciate your response.
cheers,
Krindik
krindik said:
Hi,
cheers,
Krindik
Yep, that should be pretty much it. Actually you skipped the first step, the relationship between the electric field and the source currents is integrated over all space as
\mathbf{E}(\mathbf{r}) = C\int_V \overline{\mathbf{G}}(\mathbf{r},\mathbf{r}') \cdot \mathbf{J}(\mathbf{r}') d\mathbf{r}'
I can't remember what the constant C is off hand. But in the case of the dipole, the current source is a point source and so we can drop the integration. Relating the resulting expression to what you have in the OP is a different story. They should be equivalent but it probably would require some work to show that. Chew's text doesn't derive the expression you gave originally but it's a good resource about deriving the dyadic Green's function and his chapter 2 applies it to dipoles and dipoles in layered media. Jackson's would probably work with an expression more closely related to what you gave. It's just that I am much more familiar with Chew's and Kong's texts than say Jackson.
Thanks a lot Born2bwire, u were really helpful.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
