Why is a half-wave antenna length considered optimal for efficiency?
  • Thread starter Thread starter tmiddlet
    Antenna Length
Half-wave antennas are optimal for efficiency because they create current nodes at both ends, resulting in maximum voltage anti-nodes and allowing the highest possible antenna current to flow. This design maximizes electromagnetic radiation emission. While antennas should generally not be shorter than half a wavelength, exceptions exist for very low frequencies where practical limitations arise. In such cases, quarter-wave antennas can be used, with one end grounded to effectively create a half-wave antenna. Overall, the half-wave configuration is favored for its superior performance in radiating electromagnetic waves.
tmiddlet
I have been looking into how antennas work, and I have found that antennas of half wave-length are apparently optimal, but I don't understand why. If anybody could explain why this is, I would appreciate it. Thanks! (I do have an understanding of electromagnetic waves)
an antenna absorbs the electromagnetic radiation most efficiently if it is of the same order of magnitude than the incoming wave. in the same way, if you want to stop an incoming wave on the sea side you are better of with a wall which is as high as the incoming waves rather than tiny bumbs which will be less effective at absorption.
In simplest terms, the antenna current must be zero at both ends of a half wave antenna, these are called the current nodes. But where the current nodes are zero, the voltage anti-nodes are at maximum. So you have voltage maximums at both ends of the half wave antenna causing the maximum possible antenna current to flow and the maximum amount of electromagnetic radiation from the antenna. For that reason the half wave antenna is considered to be the most efficient.
In general, an antenna should not be shorter than a half wavelength long, but you will find exceptions to this especially at very low frequencies and long wavelengths where even a half wave antenna would be too long to be physically practical. One solution is to use a quarter wave antenna and ground one end, letting the ground act as the other quarter wave, so you still have a half wave antenna. This is known as the Marconi antenna.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
