| New Reply |
Determine volume of HCl added to propionic acid to get pH=1 |
Share Thread |
| Aug4-11, 12:58 AM | #1 |
Given 250ml of 0.1M HC3H5O2 (Ka=1.35E-5) What volume of a)1.0M HCl is needed to lower the pH to 1.00. b) 1.00M NaC3H5O2 raise pH to 4.00 2. Relevant equations pH=pKa-log (HA/A) ICE chart 3. The attempt at a solution I used the ice chart for the dissociation of propionic acid. I determined the concentration of H+ and A- to be 1.16E-3. the pH was 2.93. I do not know how to factor in the HCl to determine the volume needed to lower the pH. |
| Aug18-11, 03:32 AM | #2 |
Admin
[tex]K_a = \frac {[A^-][H^+]}{[HA]}[/tex]
rearranged: [tex]\frac {[A^-]}{[HA]} = 10^{pH - pK_a}[/tex] At pH 1.0 only about 101-4.75=10-3.75=2x10-4 of the acetic acid is dissociated. That means in the first case you can - more or less safely - assume presence of acetic acid doesn't matter much, as the first approximation pH will depend mostly on the HCl dilution. Second case is just a buffer solution, use Henderson-Hasselbalch equation. |
| New Reply |
Similar discussions for: Determine volume of HCl added to propionic acid to get pH=1
| Titration of unknown acid in lab, how to determine molar mass? | Biology, Chemistry & Other Homework | 5 | ||
| Determine the molarity of NaOH used to titrate acetic acid. | Biology, Chemistry & Other Homework | 6 | ||
| HELP!! How to find a method to determine the molar mass of a soluble acid X?? | Biology, Chemistry & Other Homework | 1 | ||
| Energy added to Ice- determine final temperature | Introductory Physics Homework | 4 | ||
| volume of pool acid | Biology, Chemistry & Other Homework | 1 | ||
