Uncertainty principle and electrons
ralqs
I've been exposed to two different interpretations of the uncertainty principle.
1) If an electron is in a certain state, a measurement of its position will yield a definite result. However, if after the measurement the electron could be returned to the same state, then a repeated measurement of its position will yield a different answer. Same holds for measurements of momentum. However, the standard deviation of the distribution for positions * the standard deviation for the distribution for momentum will always be greater than a certain constant.
2) Measurements are fuzzy. Measurements of, say, position will never yield a definite result, unless the momentum becomes completely unknown.
Which one is right?
The first answer is not always correct, it depends. If you prepare particles in an identical pure state, sometimes you will always get the same (or similar) answer for all of them. Ditto for repeated measurements on the same particle, i.e. it depends.
The second is true for non-commuting observables, following the Heisenberg Uncertainty Principle.
That's why I like working with Bose-Einstein Condensates: unless you've added energy to the system to stimulate radiation emission (and why do physicists ALWAYS do that?), you know precisely where every electron is: in its lowest possible energy state consistent with its parent atom's status as an independent atom or as a member of a molecule!.
Ain't that cute?
Oh, yeah! Forgot about plasmas.
Where are the electrons in a plasma?
They're totally GONE!
All you have are nuclei.
Makes for very easy work.
But, am I cheating?
To clarify further, one must be careful to distinguish the concept of a "pure state" (or a "certain state" from the OP) from the concept of an "eigenstate." An eigenstate is always a pure state, but not the other way around. An eigenstate is only defined with respect to some observable, so a state could be an eigenstate of one observable but not another (if it does not "commute"). In that eigenstate, that observable is definite, and will always come out the same, but other observables won't. So in a pure state that is not an eigenstate of that observable, the observable is not definite, and will come out spread over a statistical range that can be called an "uncertainty." Thus #1 in the OP is only true if the "certain state" is not an eigenstate of position (i.e., not a delta function), but becomes a delta function after the position measurement.
For the case of complementary observables, an eigenstate of one implies infinite uncertainty in the other. That's not strictly physically possible, except as an idealization, so more typically, we have a pure state that is not an eigenstate of either of the complementary observables, but the product of the uncertainties is above some Planck limit.
Since delta functions don't really happen in practice, I might find fault with the wording of #1. A position measurement does not really give a definite position, it only says that the object is within some small bin. The more energy used, the smaller you can make the bin, but it's never a delta function. Thus #2 sounds generally better to me, and absent the "unless..." part at that.
This is news to me; I was under the impression that a wavefunction automatically collapses into a delta function upon measurement. Are you saying this is wrong? How then would one determine the shape of a wavefunction after measurement?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In her YouTube video Bell’s Theorem Experiments on Entangled Photons, Dr. Fugate shows how polarization-entangled photons violate Bell’s inequality. In this Insight, I will use quantum information theory to explain why such entangled photon-polarization qubits violate the version of Bell’s inequality due to John Clauser, Michael Horne, Abner Shimony, and Richard Holt known as the...
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I asked a question related to a table levitating but I am going to try to be specific about my question after one of the forum mentors stated I should make my question more specific (although I'm still not sure why one couldn't have asked if a table levitating is possible according to physics). Specifically, I am interested in knowing how much justification we have for an extreme low probability thermal fluctuation that results in a "miraculous" event compared to, say, a dice roll. Does a...
