How Long Something Stays in Air Calculation. Help Needed
  • Thread starter Thread starter student54321
    Air Calculation
A kangaroo jumping to a height of 3.0 meters will remain in the air for a total time calculated using the equation d = vf(t) - 1/2 a(t)². The initial attempt yielded a time of 0.78 seconds, which only accounts for the ascent to the peak height. Since the total time in the air includes both ascent and descent, the correct duration is double that, resulting in approximately 1.56 seconds. The confusion arose from not initially considering the descent time, which is equal to the ascent time. Therefore, the total time in the air for the kangaroo's jump is 1.56 seconds.
student54321
Jumping straight up, how long will a kangaroo remain in the air if it jumps through a height of 3.0m?
d=vf(t) - 1/2 a (t)2
I Think?
Defined all variable
d=3.0 m
a=9.81 m/ss
vf=0m/s2
then:
3.0=0 - 4.905(t)2
0.61=(t)2
t=Square root of 0.611
t=0.78
I got the wrong answer. But when I multiplied my answer by two I got the right answer. Don't know why so I'll need some help here.
And I know I skipped some calulation steps in my answer, I have them written on paper.
Just thought about it. Is it because what goes up must come down? So it needs to be 2 times the time, I just calculated for the time to the top of the parabola. Am I right?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
