New Reply
Are laws of nature really the same in all reference frames?
Share Thread Thread Tools
Apr15-12, 05:50 AM   #171
Quote by DaleSpam View Post
Bjarne Wrote
Either speed, distance and/or the definition of 1 second can then not be the same. It is a simple mathematical necessity. I haven't got an excact answer where the "camel is buried"
I am just asking the simple question; - how would these space time realities look like (what would be the comparable difference) if I could jump between them, and see the differences?
I am not an expert in his field, but it is easy to see that the full story can’t have been told so far.
I also did not got the answer (yes or no) to whether the orbit circumference for example of the Earth really can be 2 different sizes, (the same orbit), according to the example mentioned above..
And if this is so, how can the law of gravity apply for both without contradictions.
DaleSpam Wrote
The two paths are not the same, so the answer is "yes, two different paths may have different lengths".
Each path is a 1D line (a helix) in a 4D curved spacetime. You can easily come up with coordinate systems where the two paths have two coordinates which are identical and constant, and you can parameterize the paths by one of the remaining coordinates, but they will always be different in at least the final coordinate. They are simply different paths with different lengths, no contradictions nor confusions.
You certainly haven't demonstrated any conflict with the law of gravity. I don't even know what you think would be contradicted here.
Let’s say observer ‘A’ and ‘B’ live in a high-rise flat.
'A' at 1st. floor and 'B' at 10th.
Between the Sun and the Earth there is a measurement tape.
Because time is ticking different for ‘A’ and ‘B’ they cannot agree about the speed and /or the distance to the Sun (the circumstance).
Because ‘A’ and ‘B’ live at the same planet they cannot be travelling with different speed.
Because ‘A’ and ‘B’ both can see the same measurement tape (between the Sun and the Earth) the distance (circumstance) of the Sun can also not be different. Because time multiplied with speed = distance (circumstance) we do in fact have a dilemma here.
So now they must both be following the same path.
The only logical possible explanation is that ‘A’ relative to ‘B’ lives in a completely transformed reality.
This mean when time is stretching, then distances and speed is doing the same.
Or ?
Apr15-12, 06:13 AM   #172
Mentor
Hi Bjarne, welcome back! It has been quite a while.
Quote by Bjarne View Post
These two statements are mutually contradictory. If they are following the same path in spacetime then one cannot be on the 1st floor at the same time that the other is on the 10th floor. I.e. as described their spacetime paths are different by approximately 30 m or so, therefore they are not following the same path in spacetime.
Not only are the paths approximately 30 m different, but that 30 m is a significant difference since there is a measurable amount of time dilation between the two paths.
Agreed. Which of the two mutually contradictory premises do you wish to keep?
Apr15-12, 06:43 AM   #173
Not only are the paths approximately 30 m different, but that 30 m is a significant difference since there is, according to you, a measurable amount of time dilation between the two paths.
The observers are following different paths, yes, - but the observed, - the orbit of the Earth is not following 2 different paths..
Let’s say ‘A' and 'B' live at the North Pole i the same high-rise flat
Hence speed and orbit distance of the Earth, - must be the same for both observers.
Speed of the Earth must be the same, since both are at the same planet. The planet cannot be moving with 2 different speeds at the same time.
Distance is also the same.. The measurement tape between the Sun and the Earth would prove for both A and B, that distance is the same.
This means ‘A’ and ‘B’ cannot say that these factors are different.
Hence still the conclusion mentioned above, - that both speed and distance transform proportional with time, - seems to be the most and only logical.
Apr15-12, 07:22 AM   #174
Mentor
That isn't how clocks work. They only measure the length of their own path through spacetime, not some other objects path. A's clock measures the length of A's path through spacetime, not the length of B's path nor the length of Earth's path. Similarly for B.
Also, since Earth is not a point like object in this scenario, the Earth does not have a single path through spacetime unless you define one specific point as the reference point.
Why not? Speed is a frame variant quantity, so it can have as many different values at the same time as you have reference frames.
For instance, suppose one police officer is on the side of the road and another is driving on the road and suppose that they each measure the speed of the same car at the same time. One may get 100 km/h and the other may get 0 km/h. Both are valid measurements of the speed of the car, but in different frames.
Apr15-12, 10:44 AM   #175
Let's say it really was possible to tie a tape measure to the North Pole of the Sun and to the North Pole of the Earth in the other end.
A and B is in this example only observers to the Earth orbiting the Sun.
Both can see the radius / circumstance of the orbit of the Earth and both agree that the orbit of the Earth (as just defined) really is the same for both observers, - simple because both can observe this is how the tape measure proves it to be.
So both must agree that distance / circumstance of the radius/orbit of the Earth, is observed from both observers perspective to be the same.
A and B live at the North Pole in the same building ( ‘A’ at 1st and ‘B’ at 10th floor) . They are not moving relative to each other and also not relative to the Earth.
A and B and the Earth is all exactly following the same orbit, and hence in the same frame.
We could also say that also at the North Pole of the Sun there was a similar building, and from each floor a tape measure to the building / same floors at Earth's North Pole.
A and B would agree that all tape measure was the same length.
How can you then say they are in different frames / moving relative to each other?
Apr15-12, 05:42 PM   #176
Mentor
I agree. By the way, I really like how you not only specified what you wanted to measure, but also the experiment to measure it.
That would be true if spacetime were flat. I.e. in flat spacetime A not moving relative to B implies that A and B are at rest in the same frame. However, the spacetime is not flat, but is curved, and in curved spacetimes reference frames are local. For example, although the distance wrt each other is not changing (an indicator of the same frame in flat spacetime), signals from A are redshifted when received by B (an indicator of different frames in flat spacetime). So A and B are not considered to be using the same reference frame despite the fact that they are not moving relative to each other.
Besides, haven't you been assuming that A and B are different reference frames and therefore claiming that the laws of physics are different in different reference frames? It seems strange for you to change your position on this topic after this long when it hasn't been a point of disagreement until now.
Apr16-12, 02:33 PM   #177
I understand this.
I also understand that A and B could move with different speed, - but since there is a different option, (mentioned above) that also can be true - it seems there is a chose between two options.
I mean, we know that both time and speed is comparable different factors, but the fact that we don't know whether also distance are affected or not, must mean the complete picture still is an open question.
Did I ? - if so it was not my intention.
I mean I believe that the laws of nature are the same in all space time reference frames. I am just wondering which possible changing (with distance and speed) possible can ‘follow’ time dilation.
I think we don't disagree about anything, - if it is correct understood that we both agree, that what happen with speed and distance, in different space-time not is fully understood / proven.
And this is really what confuses me. - If that was clearer, I think it would be much easier to understand general relativity.
Apr16-12, 02:56 PM   #178
Mentor
I understand this.
Actually, there are an infinite number of possible coordinate systems, and therefore an infinite number of choices, not just two. Any of them is valid.
Well, the reason that it was still open is that we hadn't defined a measure of distance. If you use your ruler-based measurement of distance then distance is frame-invariant.
That is why it is so important to specify the experiment you are using to perform a measurement. If you are sufficiently clear about what it is that you are measuring then you can get a complete picture of that scenario, it is only when you ask ambiguous questions that you get ambiguous answers.
What happens according to the theory is fully understood, and many aspects (though not all) are also experimentally proven. However, because of the nature of GR it is very important to ask well-defined questions, and that is what can seem like it is not fully understood. I.e. it is not the theory but the question which is not fully understood.
If you get into the habit of thinking about how you can measure a quantity of interest then you will generally be able to ask better questions and get better answers.
Apr17-12, 12:57 AM   #179
Right
But still relativity and the fact that space curves is really strange.
I mean our immediate understanding is that space is nothing
How can nothing curve?
And how can we know whether or not something happens to distances too, and if so what happens to distances, - and to the ruler?
You say that speed is different seen from the perspective of A and B.
But if distance also is a proportional variant still speed would be different, but the whole concept would too.
What I am trying to say, - we cannot cut a piece of “curved space” in cardboard and say , - This is like it really and objective looks like, this is how we can imagine what we are talking about.
The nature of "curvature of space" is a difficult to relate to, even in our fantasy. It doesn’t make it easier when we cannot know for sure whether distances and the ruler not is affected or could be.
So how sure can we be that "the theory" "is it", - or whether there is more to come ?
I think many do have a problem to accept what seems to be huge contradiction, for example that A and B is moving with different speed. Even though eveybody can see this is not the case, since they live in the same building at the Noth Pole. Is our understanding really complete?
The opposite of a fact is falsehood, but the opposite of one profound truth may very well be another profound truth.” Niels Bohr
New Reply
Thread Tools
Similar Threads for: Are laws of nature really the same in all reference frames?
Thread Forum Replies
GR in all frames of reference Special & General Relativity 7
Concerning reference frames Special & General Relativity 5
Reference frames Introductory Physics Homework 9
frames of reference Introductory Physics Homework 8
Frames of reference & Inertial frames Classical Physics 2
