About the experiment to find the reactance of inductor
The experiment focused on determining the reactance of an air-core inductor versus a soft-iron core inductor, revealing distinct graph behaviors. The air-core inductor's Vrms versus Irms graph passes through the origin, while the soft-iron core inductor's graph exhibits a negative y-intercept. This discrepancy raises questions about potential errors, the linearity of permeability, and the maximum current measured. Participants suggest analyzing the χ2 values for the fits and recommend sharing plots for more detailed feedback. The discussion emphasizes the importance of understanding these results for upcoming public exams.
lindacheung66
I have just done an experiment on finding the reactance of (a)an air-core inductor and (b)an inductor with a soft-iron core.
I have plotted a graph of Vrms against Irms for each experiment.
For the graph in (a), the straight line can pass through origin; yet, for the graph in (b), the straight line cannot pass through the origin, but have a negative y-intercept.
However, I cannot find an answer to explain this.
Could anyone please kindly tell me why the graph in (b) cannot pass through the origin??
It seems to be quite strange result. Have you analysed errors? What is a χ2 of the fit you made and what would be χ2 for a proportional fit (going through 0,0)?
Or maybe you went out of the linear region of permeability? What was the max current you measured and how many turns your coil has?Post your plots if you want more detailed comments.
Since this experiment will be counted in the public exam, I cannot post it on the internet.
Would you mind if you give me your email address so that I can send you my graphs?
Sent to you as a private message.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
