Terminal Velocity
by sarmar
Tags: terminal, velocity
sarmar
sarmar is offline
#1
Oct2-11, 12:23 PM
P: 8
Calculate the terminal velocity for a pollen grain falling through the air using the drag force equation. Assume the pollen grain has a diameter of 7 Ám and a density of 0.3 g/cm3.
2. Relevant equations
Vterm= sq.rt of 2mg/pA
Volume= 4/3pi*r^2
Density = m/v
3. The attempt at a solution
I am given the answer but need to show how to get there.
Here is what I have, can someone point out where exactly I am going wrong?
Thank you!!
p= air density of 1.3kg and
A = cross section of the pollen grain
A= 7Ám = 0.000007m
To find mass of pollen grain:
radius= 1/2diameter
= 1/2(0.000007)
= 0.0000035m
Volume= 4/3pi*r^2
= 4/3pi(0.0000035)^2
= 5.13x10^-11 m^3
Density = m/v
m=DV
=0.3g/m^2 (5.13x10^-11 m^3)
= 1.54 x10^-11g
to kg = 1.54 x10^-14 kg
So, Vterm= sq.rt of 2mg/pA
Vterm = sq.rt. of 2(1.54 x10^-14 kg)(9.8m/s^2) / (1.3kg/m^2)(0.000007m)
=0.0018m/s
But I know this is wrong since I am given the final answer, which is 0.145m/s
I've worked it out so many times and I'm stuck. Please help.
Phys.Org News Partner Science news on Phys.org
NASA's space station Robonaut finally getting legs
Free the seed: OSSI nurtures growing plants without patent barriers
Going nuts? Turkey looks to pistachios to heat new eco-city
Doc Al
Doc Al is offline
#2
Oct2-11, 12:45 PM
Mentor
Doc Al's Avatar
P: 40,883
Quote Quote by sarmar View Post
Are you assuming a drag coefficient = 1?
A= 7Ám = 0.000007m
7Ám is the diameter of the pollen grain.
sarmar
sarmar is offline
#3
Oct2-11, 01:14 PM
P: 8
Quote Quote by Doc Al View Post
I am not given any information for drag coefficient. So I suppose I was assuming 1. I found online the drag coefficient of a spherical object is approx. 0.5
I thought the diameter was the same as the cross-section.
Area of a circle? A=p*r^2
=pi*0.0000035^2
=3.85x10^-11 so,
A=cross-section=3.85x10^-11
so then I just re-figure the mass ?
Doc Al
Doc Al is offline
#4
Oct2-11, 01:20 PM
Mentor
Doc Al's Avatar
P: 40,883
Terminal Velocity
That sounds OK.
No, A is the cross-sectional area.
=pi*0.0000035^2
=3.85x10^-11 so,
Looks OK.
Why would you re-figure the mass?
sarmar
sarmar is offline
#5
Oct2-11, 02:17 PM
P: 8
Well because I'm still not getting the right answer....
Doc Al
Doc Al is offline
#6
Oct2-11, 02:45 PM
Mentor
Doc Al's Avatar
P: 40,883
radius= 1/2diameter
= 1/2(0.000007)
= 0.0000035m
Volume= 4/3pi*r^2
That should be: 4/3pi*r^3.
sarmar
sarmar is offline
#7
Oct2-11, 04:15 PM
P: 8
Thank you!
Register to reply
Related Discussions
Terminal Velocity given Time at which velocity is .5Vt Introductory Physics Homework 6
Terminal Velocity Classical Physics 6
Terminal Velocity Introductory Physics Homework 7
Question about exhaust velocity and terminal velocity Special & General Relativity 5
Terminal Velocity Classical Physics 1
