How do I find the parametric equations for a plane?
  • Thread starter Thread starter vg19
    Plane
The discussion focuses on deriving the parametric equations for the plane defined by the equation 2x + y - z = 4. The normal vector of the plane is identified as (2, 1, -1). To find the parametric equations, participants suggest determining three intercept points: (2, 0, 0), (0, 4, 0), and (0, 0, -4). Two direction vectors are calculated using the cross product method, resulting in (0, -1, -2) and (-2, 2, -1). The final parametric equations are expressed as x = 0 + at + bs, y = 0 - ct, and z = 4 + dt, where a, b, c, and d are real numbers.
  • Understanding of parametric equations
  • Knowledge of vector operations, specifically cross products
  • Familiarity with plane equations in three-dimensional space
  • Basic algebra for manipulating equations
  • Study vector cross product calculations in detail
  • Learn about the geometric interpretation of parametric equations
  • Explore different methods for finding points on a plane
  • Investigate applications of parametric equations in 3D modeling
Students, mathematicians, and engineers who are working with three-dimensional geometry, particularly those involved in vector calculus and parametric modeling.
vg19
Hi,
Given the plane 2x + y - z = 4, find its parametric equations.
This question seems simple, but the solution is not coming to me. I know the normal is (2,1,-1). But how do I find out the direction vectors and the points for the parametric equations?
I would suggest finding three points on the plane and create two direction vectors and a point for your parametric equation. The easiest three points would be the intercepts. if y and z are 0, the co-ordinate becomes: (2,0,0). Using a similar process, you can find the two other intercepts, which are:
(2, 0, 0)
(0, 4, 0)
(0, 0, -4)
Thus, you can create two direction vectors and a third point. I think there is an easier way to approach this, but for now it eludes me.
Hi there,
To find the parametric equations for a plane, we need to first find two direction vectors that lie on the plane. One way to do this is by finding the cross product of the normal vector with any other vector that is not parallel to it. So in this case, we can choose the vector (1,0,0) to find the first direction vector. The cross product of (2,1,-1) and (1,0,0) is (0,-1,-2).
Next, we can find a second direction vector by taking the cross product of the first direction vector and the normal vector. So the second direction vector would be (-2,2,-1).
Now, to find the points for the parametric equations, we can choose any point on the plane and use it as the origin. Let's say we choose the point (0,0,4). Then, our parametric equations would be:
x = 0 + at + bs
y = 0 - ct
z = 4 + dt
Where a,b,c,d are any real numbers and t and s are the parameters that will help us generate points on the plane.
I hope this helps! Let me know if you have any other questions.
  • · Replies 33 ·
