Calculating Energy Loss with Ballistic Pendulum
Energy loss in a ballistic pendulum setup is calculated by comparing the initial kinetic energy of the projectile to the final gravitational potential energy after the collision. The initial kinetic energy is 0.929 J, while the final potential energy is 0.198 J, resulting in an energy loss of 0.731 J. This loss is attributed to factors such as friction, air resistance, and waste heat during the collision. The collision between the projectile and the pendulum is typically inelastic, meaning that kinetic energy is not conserved. Understanding these energy transformations is crucial for analyzing the efficiency of the ballistic pendulum.
paxian
How was energy lost while using the ballistic pendulum?
Initial KE= 1/2mb*Vb^2 = 0.929J
Final Potential graviational = (m+M)gh= 0.198J
Energy loss = 0.929J - 0.198J= 0.731J
I think the answer is:
energy lost dues to friction (air resistance) and waste heat while using the ballistic pendulum.
is this correct? Please help? Thanks a lot in advance.
What kind of collision occurs when the ball (projectile) collides with the pendulum?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
