Compute the focal length in air of a thin biconvex lens
The focal length of a thin biconvex lens with a refractive index of 1.5 and radii of 20 cm and 40 cm is calculated using the lens maker's formula: 1/f = (n-1)(1/R1 - 1/R2), resulting in a focal length of 80 cm. When an object is placed 40 cm from the lens, the magnification (Mt) is calculated as -f/x0, yielding a value of -2 cm, indicating an inverted image. The calculations confirm that the image is virtual and magnified by a factor of 2.
  • Understanding of the lens maker's formula
  • Knowledge of optical properties of biconvex lenses
  • Familiarity with concepts of magnification and image formation
  • Basic principles of geometric optics
  • Study the derivation and applications of the lens maker's formula
  • Explore the behavior of light through different types of lenses
  • Learn about virtual and real images in optical systems
  • Investigate the effects of varying object distances on image characteristics
Students of optics, physics educators, and optical engineers seeking to deepen their understanding of lens behavior and image formation principles.
jlmac2001
Compute the focal length in air of a thin biconvex lens (n=1.5) having radii of 20 and 40 cm. Locate and describe the image of an object 40cm from the lens.
my answer:
1/f = (n-1)(1/R1-1/R2)
1/f = (1.5-1)(1/20-1/40)
1/f = .5(.025)
f = 1/.0125 = 80cm (convering lens because f is positive)
Mt=-f/x0=-80/40=-2cm (Inverted image because Mt is negative)
Did I use the correct equations?
Originally posted by jlmac2001
f = 1/.0125 = 80cm
Looks O.K. to me.
I should expect, if the object is only 40cm from the lens while the lense's focal length is 80cm, then the image should be upright and virtual, and magnified by a factor of 2.
Yes, you used the correct equations to calculate the focal length and image distance for a thin biconvex lens. Your calculations are also correct, and your description of the image is accurate. Well done!
  • · Replies 19 ·
