Matlab: If/Elseif 2 conditions.
  • Context: MATLAB
  • Thread starter Thread starter Beer-monster
    Conditions Matlab
This discussion focuses on implementing conditional statements in MATLAB, specifically using the OR operator to execute code under multiple conditions. The user seeks to execute the same series of calculations if either the scalar value dE is less than or equal to zero or if r is less than or equal to w. The solution involves using the logical OR operator (|) in a single if statement rather than separate if and elseif statements, which is a more efficient approach in MATLAB programming.
  • Basic understanding of MATLAB programming
  • Familiarity with conditional statements in programming
  • Knowledge of logical operators in MATLAB
  • Experience with scalar variables in MATLAB
  • Learn about MATLAB logical operators, specifically the OR operator (|)
  • Explore MATLAB's conditional statements and their syntax
  • Investigate best practices for writing efficient MATLAB code
  • Review MATLAB documentation on control flow and logical conditions
MATLAB programmers, data analysts, and anyone looking to optimize their use of conditional statements in MATLAB for efficient coding practices.
Beer-monster
Hi
I'm new to MATLAB and I'm trying to write a code that executes the same process under two separate conditions>
condition 1: that scalar value dE is less than or equal to zero.
condition 2: that scalar value r is less than or equal to scalar value w.
I'd like to same series of calculations to be executed if either of these conditions are true (or both) like an OR statement.
I've tried to accomplish this using an if and elseif combination.
r=0
w=1
dE=0
L1=ones(N)
for i=1:t
if (dE<=0)
elseif (r<=w)
<program statements>
else
<final condition>
end
However, it does not seem to be working. Most examples of the elseif statement I've seen online has two separate series of commands for the if and elseif condition
e.g
if expression1
<program statements1>
elseif expression2
<program statements2>
end
Is it possible that my code will not work unless I write the if/elseif statements separate (i.e. copy and paste my current process)? If so, is there another method I could use or do I need to repeat my statements.
Thanks
MATLAB also allows you to do disjunctive conditions. What're disjunctive conditions? That's fancy-talk for OR-ing two things (in this case, using the OR operator, the pipe |). If you're familiar with C, that probably looks pretty familiar--in fact, MATLAB uses the same operators, both logical and bit-wise.
Assume you have two numbers A and B. Let's say you want some code to execute if A is less than 5 or B is >10. To do that, you'd do the following:
Code:
if (A < 5 | B > 10)
     A * B
end
For completeness sake, it's usually best to put brackets around logical conditions in the order that you wish for them to be evaluated (say, when you have three or more operations or conditions--it's not always left to right).
Unfortunately, the only way an elseif statement would work is if you pasted the exact same code under the if statement as you do under the else-if statement. In short, use the power of logical operators:
http://www.mathworks.com/help/techdoc/matlab_prog/f2-97022.html#brftcpu-1
Great. That helped a lot. Thanks.
11K
  • · Replies 41 ·
11K
