Can You Convert 3 Phase 208V to Single Phase for a Heat Wheel?
  • Thread starter Thread starter richardv24
    Project
To convert a 3-phase 208V power source to single-phase for a heat wheel, connect one phase to hot, the neutral to neutral, and ground to ground. If the 3-phase system lacks a dedicated neutral, one of the hot phases can be used, but this may not provide the correct voltage. The line-to-neutral voltage in a 208V system is actually 120V, so ensure the heat wheel is indeed designed for 208V. It's advisable to consult an electrical expert for proper guidance on this conversion. Proper connections are crucial for safe and effective operation.
richardv24
Hey guys thanks in advance for any help,
I have a 3 phase 208 volt power source and I have something (heat wheel) that runs on 208 single phase. The heat wheel has ports labeled H (hot) N(neutral) G (gnd). I believe that if i take two legs of the 208 v 3ph, It should now be a single phase. However, one leg would go to hot, gnd would be gnd, does the other leg (which is hot as well), go to neutral?
Thanks again
You hook the hot to one of the phases, neutral goes to neutral and ground goes to ground. Your 3 phase should have 3 hots and a neutral if it doesn't just hook the neutral to one of the hots on your 3-phase. The problem with that is that you won't get 208 volts.
Read this: http://en.wikipedia.org/wiki/Single-phase_electric_power
208 Volt is an unusual voltage for something to be designed for.
Are you sure it's 208 Volt.
The line to neutral voltage of 208 volt is only 120 volt.
If your device is designed for 208 volt, then it should be connected line to line.
This is not my area of expertise, so you probably should get help from someone who is an expert in this area.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
