Root Finding Exercise - Finding Value for Equivalent Areas
The discussion focuses on finding the unknown parameter in a fountain design that creates a hyperbolic shape through water spray. The goal is to ensure the areas of the top and bottom parabolas are equivalent, with the bottom's parameters known and one parameter of the top still unknown. Participants suggest using root-finding methods, such as the bisection method or Newton-Raphson, to compute this unknown value. They recommend starting with trial values to establish bounds for the area difference, which can then be refined to find where the area function equals zero. The conversation emphasizes the importance of clarifying the equations involved to effectively apply these mathematical techniques.
architenginee
How to find value in root finding exercise?
I am designing a fountain for a Vegas hotel which sprays water in the shape of a hyperbola onto a screen. The hyperbolas shape is a function of several different variables. I am looking for conditions which will cause the area cast by the bottom and top parabolas to be equivalent. The parameters for the bottom shape are given, while those for the top are also given with the exception of 1 value. How do I compute the value of this unknown by root finding.
My notes up to now:
-compute area of bottom with given info
-area of top = area of bottom
...I have a program which integrates the area with given input...but I am stuck
Technology news on Phys.org
Imagine two nozzles with different parameters such as, nozzle area, pressure, density of medium, etc...these are just arbitrary examples to help give perspective to the problem at hand...
0 seconds ago
Hyperbola or parabola? You are using both terms here.
My notes up to now:
I'm going to assume you meant parabola, not hyperbola. The equation y = 2x - x2 is a parabola that opens downward, and whose vertex is at (1, 1) and whose x-intercepts are at (0, 0) and (2, 0). It can be shown that the area between the parabola and the x-axis is 2/3.
If you reflect this parabola across the x-axis, you get a new parabola with equation y = -2x + x2. The x-intercepts are still at (0, 0) and (2, 0), but now the vertex is at (1, -1). The area between this parabola and the x-axis is also 2/3.
Seems like you might be able to use this idea in your fountain.
I have found how to compute the area. The issue at hand is how to go about solving for the missing parameter by root finding method. (bisection/Newton-raphson, etc)
Your description of what you're trying to do is too vague for me to be able to give any specific advice.
architenginee said:
My notes up to now:
Assuming the area monotonically increases, or decreases,
By trial and error find one value of the unknown parameter so the resulting area is too small and a second value of the unknown parameter so the resulting area is too large. Then consider area of lower-area of upper and you want to find where that function is zero.
Now you have a classic "bisection" problem.
Read this and think how you can apply that to your task.
http://en.wikipedia.org/wiki/Bisection_method
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
