Calculating Tension Force Problem
The problem involves calculating the tension force exerted on a string by a ball swinging in a horizontal circle. The ball has a mass of 2.7 kg and is attached to a 72.0 cm string, completing one revolution in 0.98 seconds. Participants are exploring the concepts of tension force and circular motion.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • The original poster attempts to apply basic physics formulas, including displacement and Newton's Second Law, but expresses uncertainty about the correct application of these concepts. Some participants question the assumptions made about the radius and the forces acting on the ball, while others suggest using diagrams to clarify the situation.
Participants are actively discussing the problem, with some providing hints and guidance on how to approach the calculation of tension force. There is recognition of the need for a clearer understanding of the forces involved and the geometry of the situation, but no explicit consensus has been reached on the correct method or interpretation.
There is uncertainty regarding the interpretation of the string length as the radius of the circular path, and participants are considering the implications of this on the calculations. The original poster is also unsure about the relevance of certain forces, such as normal force and friction force, in this context.
Declension
A girl swings a 2.7kg ball attached to a 72.0-cm string in a horizontal circle above her head, which makes one revolution in .98s. What is the tension force, [tex]F_{T}[/tex], exerted on the string by the ball?
Alright, I have never worked with Tension Force in my class, but we have worked with basic physics formulas, which I applied to this problem. Since mass and time are given, I assumed to use Displacement & Time (assuming 72cm [or 0.72m] is displacement instead of radius, since I'm unsure if it's radius or not...), which is:
[tex]x = x_0 + v_0 t + (1/2) a t^2[/tex]
For the second part, I applied Newton's Second Law to find Tension Force.
[tex]{F} = {m}{a}[/tex]
or (assuming [tex]v_0[/tex] is 0):
0.72 = (1/2) (a) (0.98)^2
And for acceleration I got [tex]1.49 (m/s)^2[/tex].
Then, applying Newton's Second Law:
or
F = (2.7)(1.49) = 4.04 N.
However, my only available answers are 3.8N, 3*(10^3)N, 8*(10^1)N, and 92N.
I would of rounded 4.04N to 3.8N and moved on, but I have a strong feeling I did this entire problem wrong.
If I did, could someone explain what I did wrong and guide me in the right direction?
Thanks!
It would be help if you drew a picture or diagram of this problem and labeling all the forces acting on the ball. I'm curious as to where you got the equation x=x0+v0t+(1/2)at2 from.
This is what I drew on my paper. My diagram is what originally confused me (It's a bad one).
I assumed Force of Gravity (mg) is acting on the ball, but I'm unsure if any other forces are acting upon it. I do know there is tension on the string by the ball, because that is what I'm solving for.
I was unsure if there is any Normal Force, Friction Force, or Applied Force [tex](F_N, F_f, F_p)[/tex], so I resorted to the formula for Uniformly Accelerated Motion.
I resorted to that formula for Uniformly Accelerated Motion, since I have Distance and Time, and I'm trying to find Acceleration so I can find Tension Force.
I could use Centripetal Acceleration to find acceleration, but I don't have a Velocity, and I'm instead given other variables (mass, time, distance [or radius, still not sure]).
I'm just completely lost and confused at this point.
I agree the diagram you drew is confusing. How I read the problem was the horizontal circle's radius is the length of the string. You can get the velocity since you have the period.
This is a circular motion / centripetal acceleration problem. Hints: Realize that the string must make an angle with the horizontal. Apply Newton's 2nd law.
hey Doc Al, are you referring to a tether ball diagram because I got confused after your response.
Yes, it would look something like a tether ball diagram. Same basic idea.
I'm assuming I use [tex]V = {x}/{t}[/tex]
with x = 0.72m?
V = x/t is for linear motion, to find speed here you have to use angular velocity because it is circular/rotational motion.
with x = 0.72m?
Two problems here:
(1) The distance traveled in one revolution will equal the circumference of the circle.
(2) 0.72m is the length of the string, not the radius of the circular path.
This is quite an involved problem. As I pointed out earlier, while the circle is horizontal, the string is not. You'll need a bit of trig to relate the length of the string to the radius, in addition to what I mentioned earlier.
Start by drawing an accurate diagram.
  • · Replies 18 ·
  • · Replies 19 ·
