Moment of inertia wheel and bug
The problem involves a rotating wheel with spokes and a bug located on one of the spokes. The wheel has a specified angular velocity and radius, while the bug's position and mass are also given. The discussion centers around calculating the angular and linear speeds of the bug.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between the angular speed of the wheel and the bug, questioning the need for additional information such as time for the angular velocity. There are also inquiries about the implications of the bug's position on the spoke regarding its linear speed.
Some participants have offered guidance on the relationship between the angular speed of the wheel and the bug, while others express uncertainty about the simplicity of the calculations involved. Multiple interpretations of the problem are being explored, particularly concerning the effects of the bug's position on the wheel.
There is a mention of negative acceleration of the wheel, although the specifics are not provided. The lack of time information is also noted as a potential constraint in the discussion.
Jdanka
There is a wheel with spokes rotating on a horizontal axis about its center.
the Wheel has a w(omega) of 6∏ and a radius of .04meters
there is a bug on one of the spokes at exactly 1/2 radius or .02meters. the bug has a mass of .005kg.
not really sure which equations to use, but here are a bunch that will most likely be helpful
Icm of rod = 1/3mL^2
Icm of wheel = Mr^2
v=w/r
a=σ(alpha)*r
The questions are
A) find the angular speed of the bug
B) find the linear speed of the bug
these are just the first couple questions of many but any help would be appreciated.
"the Wheel has a w(omega) of 6∏ and a radius of .04meters"
If you are specifying the rotational speed of the spoked wheel, you need more units.
Six pi radians in what amount of time?
there is no time given, but what might be helpful to know is that the wheel has a negative acceleration (was not given the amount). also incase it wasn't clear the wheel is rotating vertically
unfortunately I have a very difficult physics teacher. I don't need the answer in numbers nor do i want it, but I would like to know how to solve this
If the bug is clinging to a spoke, then it is moving with the wheel. That tells you its angular speed. To determine its linear speed, you already have the equation posted to do that.
Is it really that simple to find angular velocity? i thought for sure that I would have to use some form of energy to find it using I. and as far as linear velocity goes I thought because it was not on the outside of the wheel that it would have a different velocity than a point on the wheel
The angular speed of the bug is the same as the angular speed of the wheel. For the linear speed, you have the formula V = omega * r. You typed it incorrectly in your original post.
  • · Replies 21 ·
15K
  • · Replies 40 ·
  • · Replies 25 ·
